查看: 23960|回复: 84
Xilinx System Generator for dsp
发表于 2007-1-30 22:24:44 | 显示全部楼层 |阅读模式
version 8.2.02 ,user's guide
part 1
Xilinx is disclosing this Document and Intellectual Property (hereinafter “the Design”) to you for use in the development of designs
to operateon, or interface with Xilinx FPGAs. Except as stated herein, none of the Design may be copied, reproduced,
distributed, republished, downloaded, displayed, posted, or transmitted in any form or by any means including, but not limited to,
electronic, mechanical, photocopying, recording, or otherwise, without the prior written consent of Xilinx. Any unauthorized use of
the Design may violate copyright laws, trademark laws, the laws of privacy and publicity, and communications regulations and
statutes.
Xilinx does not assume any liability arising out of the application or use of the Design; nor does Xilinx convey any license under
its patents, copyrights, or any rights of others. You are responsible for obtaining any rights you may require for your use or
implementation of the Design. Xilinx reserves the right to make changes, at any time, to the Design as deemed desirable in the
sole discretion of Xilinx. Xilinx assumes no obligation to correct any errors contained herein or to advise you of any correction if
such be made. Xilinx will not assume any liability for the accuracy or correctness of any engineering or technical support or
assistance provided to you in connection with the Design.
THE DESIGN IS PROVIDED “AS IS” WITH ALL FAULTS, AND THE ENTIRE RISK AS TO ITS FUNCTION AND
IMPLEMENTATION IS WITH YOU. YOU ACKNOWLEDGE AND AGREE THAT YOU HAVE NOT RELIED ON ANY ORAL OR
WRITTEN INFORMATION OR ADVICE, WHETHER GIVEN BY XILINX, OR ITS AGENTS OR EMPLOYEES. XILINX MAKES
NO OTHER WARRANTIES, WHETHER EXPRESS, IMPLIED, OR STATUTORY, REGARDING THE DESIGN, INCLUDING ANY
WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE, AND NONINFRINGEMENT OF
THIRD-PARTY RIGHTS.
I
N NO EVENT WILL XILINX BE LIABLE FOR ANY CONSEQUENTIAL, INDIRECT, EXEMPLARY, SPECIAL, OR INCIDENTAL
DAMAGES, INCLUDING ANY LOST DATA AND LOST PROFITS, ARISING FROM OR RELATING TO YOUR USE OF THE
DESIGN, EVEN IF YOU HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. THE TOTAL CUMULATIVE
LIABILITY OF XILINX IN CONNECTION WITH YOUR USE OF THE DESIGN, WHETHER IN CONTRACT OR TORT OR
OTHERWISE, WILL IN NO EVENT EXCEED THE AMOUNT OF FEES PAID BY YOU TO XILINX HEREUNDER FOR USE OF
THE DESIGN. YOU ACKNOWLEDGE THAT THE FEES, IF ANY, REFLECT THE ALLOCATION OF RISK SET FORTH IN THIS
AGREEMENT AND THAT XILINX WOULD NOT MAKE AVAILABLE THE DESIGN TO YOU WITHOUT THESE LIMITATIONS
OF LIABILITY.
The Design is not designed or intended for use in the development of on-line control equipment in hazardous environments
requiring failsafe controls, such as in the operation of nuclear facilities, aircraft navigation or communications systems, air traffic
control, life support, or weapons systems (“High-Risk Applications”). Xilinx specifically disclaims any express or implied
warranties of fitness for such High-Risk Applications. You represent that use of the Design in such High-Risk Applications is fully
at your risk.
2000 - 2006 Xilinx, Inc. All rights reserved. XILINX, the Xilinx logo, and other designated brands included herein are trademarks
of Xilinx, Inc. All other trademarks are the property of their respective owners.
[ 本帖最后由 dukeblack 于 2007-1-30 22:47 编辑 ]
sysgen_ug.part01.rar
1.86 MB, 下载次数: 349 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-1-30 22:27:19 | 显示全部楼层
part2
sysgen_ug.part02.rar
1.86 MB, 下载次数: 274 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-1-30 22:30:25 | 显示全部楼层
prat3
sysgen_ug.part03.rar
1.86 MB, 下载次数: 265 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-1-30 22:32:55 | 显示全部楼层
part4
sysgen_ug.part04.rar
1.86 MB, 下载次数: 245 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-1-30 22:35:51 | 显示全部楼层
part5
sysgen_ug.part05.rar
1.86 MB, 下载次数: 254 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-1-30 22:38:32 | 显示全部楼层
part6
sysgen_ug.part06.rar
 楼主| 发表于 2007-1-30 22:40:01 | 显示全部楼层
part7
sysgen_ug.part07.rar
927.27 KB, 下载次数: 193 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-8-9 17:03:13 | 显示全部楼层
真实好东西啊,
谢谢哦、楼主
发表于 2007-8-9 17:05:05 | 显示全部楼层
这么好的东东怎么每人顶呢!!!
发表于 2007-9-3 11:11:04 | 显示全部楼层
bu yao  gao xiao ha  ,zhe ge  bu shi  bangzhu  wenjian ma  ?
GMT+8, 2025-12-15 15:41 , Processed in 0.180519 second(s), 7 queries , Gzip On, Redis On.
