查看: 2574|回复: 4
[讨论] QuestaSim help
发表于 2013-7-15 17:11:33 | 显示全部楼层 |阅读模式
I have just started working with QuestaSim. Before that i was working with modelsim. Is there anybody know what feature QuestaSim has that modelsim doesn't have? I mean in case of systemVerilog and verification
发表于 2013-7-15 20:06:35 | 显示全部楼层
这个和modelsim有什么区别
发表于 2013-7-15 20:07:48 | 显示全部楼层
you can study it from it's example files.
发表于 2013-7-15 20:09:26 | 显示全部楼层
The example is under the setup directory.
发表于 2013-7-16 09:06:44 | 显示全部楼层
回复 1# setare90
modelsim for fpga and sample asic testing/verification, questasim for asic and fpga verification;
questasim has some new features than modelsim, for example : uvm/ovm/vmm verification methodology, verification manage tools, low power verification tools and better performance. if your projection is some bit big, I suggest you to use questasim for your work.
GMT+8, 2025-12-14 01:53 , Processed in 0.021820 second(s), 8 queries , Gzip On, Redis On.
