查看: 1848|回复: 0
[招聘] NO.82-Sr Analog Design Engineer(Shanghai)
发表于 2013-7-11 16:54:42 | 显示全部楼层 |阅读模式
Responsibilities:
Implement critical analog circuitries, such as charge pump, bandgap, reference voltage/current, ADC/DAC etc., for memory operation
Perform transistor level simulations for functionality, performance and optimization
Perform block level and full chip level simulations using mixed-signal simulators
Define, design and verify architecture for embedded non-volatile memories
I/O design experience a plus
Other duties as and when required.
Mandatory Skills:
Must be good at problem solving
Must have the ability to communicate effectively with different levels of employees/customers
Knowledge and ability to use computer tools such as HSPICE, SPECTRE, digital simulation(NC-verilog), mixed-signal simulator, static timing analysis and test generation
Knowledge of layout verification tools and debugging techniques
Some knowledge of digital RTL design and logic synthesis preferred
Education:Bachelor Degree or higher preferred
Experience:Minimum of 4 year’s experience in R&D center in Semiconductor field
Position:Regular
Shift:Day
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-23 17:38 , Processed in 0.015051 second(s), 5 queries , Gzip On, Redis On.
