查看: 3674|回复: 0
[求助] 请问usb枚举完成后,出现error:No open pipes错误
发表于 2013-6-29 13:36:21 | 显示全部楼层 |阅读模式
做了一个USB IP枚举完成后,通过USB device view查看,信息如下:
请问红色部分No open pipes是什么原因导致的,非常感谢
[Port7]
          ---===>Device Information<===---
ConnectionStatus:
Current Config Value:              0x00  -> Device Bus Speed: High
Device Address:                    0x01
Open Pipes:                           0
*!*ERROR:  No open pipes!
          ===>Device Descriptor<===
bLength:                           0x12
bDescriptorType:                   0x01
bcdUSB:                          0x0200
bDeviceClass:                      0xFF  -> This is a Vendor Specific Device
bDeviceSubClass:                   0x00
bDeviceProtocol:                   0x00
bMaxPacketSize0:                   0x40 = (64) Bytes
idVendor:                        0x11E2 = Vendor ID not listed with USB.org as of 03-19-2008
idProduct:                       0x2008
bcdDevice:                       0x0100
iManufacturer:                     0x00
iProduct:                          0x00
iSerialNumber:                     0x00
bNumConfigurations:                0x01
          ===>Configuration Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x02
wTotalLength:                    0x0027  -> Validated
bNumInterfaces:                    0x01
bConfigurationValue:               0x01
iConfiguration:                    0x00
bmAttributes:                      0x80  -> Bus Powered
MaxPower:                          0x32 = 100 mA
          ===>Interface Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x04
bInterfaceNumber:                  0x00
bAlternateSetting:                 0x00
bNumEndpoints:                     0x03
bInterfaceClass:                   0xFF  -> Vendor Specific Device
bInterfaceSubClass:                0x00
*!*CAUTION:    This appears to be an invalid bInterfaceSubClass
bInterfaceProtocol:                0x00
iInterface:                        0x00
*!*CAUTION:  0xFF is a prerelease Class ID
          ===>Endpoint Descriptor<===
bLength:                           0x07
bDescriptorType:                   0x05
bEndpointAddress:                  0x81  -> Direction: IN - EndpointID: 1
bmAttributes:                      0x02  -> Bulk Transfer Type
wMaxPacketSize:                  0x0200 = 0x200 max bytes
bInterval:                         0x00
bLength:                           0x07
bEndpointAddress:                  0x02  -> Direction: OUT - EndpointID: 2
bInterval:                         0x00
bLength:                           0x07
bEndpointAddress:                  0x03  -> Direction: OUT - EndpointID: 3
wMaxPacketSize:                  0x0007 = 0x07 max bytes
bInterval:                         0x02
GMT+8, 2025-12-25 04:54 , Processed in 0.018957 second(s), 6 queries , Gzip On, Redis On.
