查看: 3870|回复: 7
[资料] TetraMax Reference Methodology Script G-2012.06
发表于 2013-6-21 12:09:12 | 显示全部楼层 |阅读模式
G-2012.06
This section describe new features, changes, and enhancements in the
TetraMAX Reference Methodology version G-2012.06.
*  The pattern optimization flow has been added.
   The new $TMAX_OPTIMIZE_PATTERNS runtime variable controls this flow.
*  On-chip clocking support has been added for designs containing on-chip clock
   controllers.
   A new option, On-Chip Clocking, has been added in RMgen. You should set this
   option to the same value for both the Design Compiler and TetraMAX reference
   methodologies.
   Set On-Chip Clocking to TRUE when you want to use the phase-locked loop (PLL)
   clock for transition delay and other dynamic tests and use the bypass clock
   for stuck-at and other static tests. When this option is set to FALSE, all
   clocks are controlled by primary inputs.
*  The tmax_diagnosis.tcl file has been updated to use the new Library Exchange
   Format/Design Exchange Format (LEF/DEF) flow for physical diagnosis instead of
   the old Milkyway flow.
*  The TetraMAX Reference Methodology now reads the scan compression protocol file
   from Design Compiler by default because scan compression is now enabled by
   default in the Design Compiler Reference Methodology.
   Comments have been added explaining how to use the set_drc switches that are
   required by the new shared codec I/O flow support in the Design Compiler
*  The comments that described a manual workaround for simulating loadable nonscan
   cells have been removed because TetraMAX version G-2012.06 has been enhanced to
   write the correct testbench automatically.
*  The script now writes the post-DRC reports immediately after running the
   run_drc command instead of waiting until after it runs the run_atpg command.
   This change improves the accuracy of the reports and makes them available
   earlier.
TMAX-RM_G-2012.06.tar (90 KB , 下载次数: 113 )
TMAX-RM_G-2012.06-SP2.tar (90 KB , 下载次数: 133 )
发表于 2013-6-24 18:54:26 | 显示全部楼层
Thanks!!!
发表于 2016-1-20 21:19:49 | 显示全部楼层
thanks!
发表于 2021-3-8 14:43:28 | 显示全部楼层
标记一下,谢谢LZ
发表于 2021-5-31 18:09:14 | 显示全部楼层
谢谢分享
发表于 2021-10-13 21:26:18 | 显示全部楼层
好东西,谢谢分享
发表于 2025-7-9 15:49:12 | 显示全部楼层
下来看看
发表于 2025-7-10 09:14:48 | 显示全部楼层
谢谢分享!
GMT+8, 2025-9-16 05:08 , Processed in 0.020097 second(s), 6 queries , Gzip On, Redis On.
