查看: 10657|回复: 15
[求助] 做过数模混合仿真的大侠进来看下
发表于 2013-6-20 13:48:50 | 显示全部楼层 |阅读模式
所有的设置都设置好以后,仿真的时候却在CIW中提示:
"errors encountered during simulation. the simulator run log has not been generated. Possible
cause could be an invalid command line option for the version of the simulator you are
running. choose setup ->environment and verify that the command line option specified in
the userCmdLineOption field are supported for the simulator.
Alternatively run the simulator standalone using the runSimulation file in the netlist
directory to know the exact cause of the erro
请问下这是怎么回事,有人遇到过吗?还有上面提示的runSimulation 怎么用的?
发表于 2013-6-20 20:00:17 | 显示全部楼层
曾经见过和你提到的这种类似的问题,报错:“****invalid command line***"
后来cadence AE发现是环境变量出现问题,导致runsimulation生成错误。
 楼主| 发表于 2013-6-20 22:46:41 | 显示全部楼层
回复 2# 940202000
最后是怎么解决的呢?
发表于 2013-6-21 09:01:01 | 显示全部楼层
遇到该问题是因为:在cshrc中加载了finesim的环境变量,导致cadence出现的该问题。最后吧finesim的那几句环境变量注释掉  就ok了。
不确定该问题是否与你的一样?
 楼主| 发表于 2013-6-21 10:20:12 | 显示全部楼层
我没见到finesim那几句话啊,顺便问下runSimulator 怎么用呢?
发表于 2013-7-3 08:45:31 | 显示全部楼层
遇到同样问题,不知LZ有没有解决,求教!!!
发表于 2013-7-3 09:26:58 | 显示全部楼层
我在终端输入:./runSimulation
显示 :command not find
郁闷
发表于 2014-5-15 20:34:46 | 显示全部楼层
非常的感謝分享
发表于 2015-4-11 14:58:37 | 显示全部楼层
First if your spectreVerilog simulator is OK then your license feature is OK.
So, when you run "$: ./runSimulation" --->command is not found, the main problem maybe is the redhat system not install "ksh" tool, just try in terminal "$: yum install ksh"
发表于 2015-4-11 15:01:00 | 显示全部楼层
回复 6# lccchc
$: yum install ksh
GMT+8, 2025-9-15 13:46 , Processed in 0.274661 second(s), 4 queries , Gzip On, Redis On.
