查看: 3890|回复: 6
[求助] 关于Pipeline ADC的SFDR 低于0dB
发表于 2013-6-20 13:40:09 | 显示全部楼层 |阅读模式
各位大神看下,一般我们做ADC的SFDR分析时,在输入信号处,其值一般都为0dB左右是吧?为什么我的在输入信号频率处只有-25dB呢?求指教啊?
SFDR测量图
SFDR测量图
发表于 2013-7-9 13:36:41 | 显示全部楼层
那信号频率处应该是多少
发表于 2013-7-13 16:02:45 | 显示全部楼层
请问用ADC怎么做SFDR测试啊?
发表于 2013-7-16 13:52:48 | 显示全部楼层
基频都看不到?
发表于 2013-9-4 17:51:08 | 显示全部楼层
I think this has problem with choosing input frequency
发表于 2013-9-4 19:58:08 | 显示全部楼层
回复 4# mahouwen
    Use clean sinewave as input, use low jitter clock. Use logic analyzer get digital signal, take sevral signal cycle (complete cycles). Use Matlab analysis, you can take window. Then FFT, plot in dB, the dB value between main signal & maximum tone is the SFDR.
发表于 2014-6-28 16:52:29 | 显示全部楼层
sim by matlab !
GMT+8, 2025-12-30 17:43 , Processed in 0.023043 second(s), 5 queries , Gzip On, Redis On.
