查看: 2093|回复: 0
[招聘] physical design后端经理职位简历发HR@hi-talent.net
发表于 2013-6-18 22:19:25 | 显示全部楼层 |阅读模式
欢迎把简历发给我,进一步电话沟通
热招后端经理和资深后端工程师
Physical design Leader/staff engineer
这个是带团队的,需要技术和个人魅力都结合的职位
1. lead soc design team;
2. be able to interface &communicate with internal colleague and external customer;
3. be able to provide design guidance and instruction to engineers;
4. be able to hands-on work on Top level/block level physical design independently
JR:
1. minimum of 5 yrs of working experience;
2. master degree of EE or related field is preferred;
3. team leader or functional leader experience is preferred;
4. familiar with either Synopsys or Cadence design flow and EDA tools;
5. fluent in both Chinese and English
下面的职位要求,有其中之一最好没有也不强调:
1. Responsible for all aspects of physical design and implementation of integrated circuits and other ASIC.
2. Responsibilities include: Participating in the efforts in establishing CAD and physical design methodologies;
3. Focusing on full chip layout planning (partitioning, planning clock distribution and other structure, methodology);
4, Chip floor plan; Power/clock distribution;
5. Chip assembly and P&R; Timing closure;
6. Power and noise analysis;
7. Back-end verification across multiple projects;
Requirements:
1. BSEE 5+years,MSEE 3+years experience in large VLSI physical design implementation;
2. Successful track record of delivering products to production is a must;
3. Understanding of custom Macro blocks such as RAMs, PLLs, high-speed IO drivers;
4. Prior experience in Timing closure, clock/power Distribution and analysis, RC Extraction and correlation, place and route and tapeout issues;
5. Working knowledge of deep sub-micron routing issues as they relate to power and timing;
6. Circuit level comprehension of time critical paths. Spice experience a plus;
7. Should be a power user of Apollo/Astro for routing, PhysOpt (Physical Compiler) for placement, PrimeTime for Timing Verification, dc_shell etc.
PR Engneer
Responsibilities:
1. Layout database creation : layout library and Milkyway database creation;
2. Initial floorplan : Initial chip or subchip level floorplan;
3. Place & Route: Perform cells placement; Perform global route and detail route;
4.  DRC/LVS corrections; Layout script creation: Create script to perform layout modification;
5. Create Apollo scheme file to maintain and update Apollo database;
6. Layout modification: Follow signal integration report to perform necessary modification;
7. Requirements: Bachelor Degree or higher in EE major;
8. 0-3 years P&R working experience;
9. Knowledge about Solaris/Unix/Linux operating system; Good command of English in both written and oral format.
DFT Engineer
1. Responsibilities: Synthesis: Use DC (Design Compiler), ACS (Advanced Chip Synthesis), and PC (Physical Compiler) for chip synthesis either from RTL code or Gate level netlist;
2. Static Timing analysis and Formal verification: Perform timing analysis and timing optimization;
3. Run formal verification after each ECO and timing optimization;
4. DFT design: Scan chain insertion; JTAG/Boundary scan insertion; NAND tree insertion;
5. Memory BIST insertion; Logic BIST insertion;
6. Test pattern generation and simulation: ATPG test vector generation and pattern simulation;
7. Fault grading test vector generation;
8. Memory BIST simulation; JTAG/NAND tree simulation;
9. Test vectorl format conversion and provide all test related patterns to test and product engineers;
10. Requirements: BS, MS preferred; 0-3 years working experience on chip integration;
11. Strong Logic design and Semiconductor device physic background; Good English in both written and spoken.
简历发HR@hi-talent.net
GMT+8, 2025-12-23 17:43 , Processed in 0.014884 second(s), 6 queries , Gzip On, Redis On.
