查看: 8332|回复: 43
Ebook: Microtrip Filters for Mobile Communications application
发表于 2007-1-18 10:48:30 | 显示全部楼层 |阅读模式
Preface xi
1. Introduction 1
2. Network Analysis 7
2.1 Network Variables 7
2.2 Scattering Parameters 8
2.3 Short-Circuit Admittance Parameters 11
2.4 Open-Circuit Impedance Parameters 11
2.5 ABCD Parameters 12
2.6 Transmission Line Networks 12
2.7 Network Connections 14
2.8 Network Parameter Conversions 17
2.9 Symmetrical Network Analysis 18
2.10 Multi-Port Networks 21
2.11 Equivalent and Dual Networks 24
2.12 Multi-Mode Networks 26
References 28
3. Basic Concepts and Theories of Filters 29
3.1 Transfer Functions 29
3.1.1 General Definitions 29
3.1.2 The Poles and Zeros on the Complex Plane 30
3.1.3 Butterworth (Maximally Flat) Response 31
3.1.4 Chebyshev Response 32
3.1.5 Elliptic Function Response 34
3.1.6 Gaussian (Maximally Flat Group-Delay) Response 36
3.1.7 All-Pass Response 37
3.2 Lowpass Prototype Filters and Elements 38
3.2.1 Butterworth Lowpass Prototype Filters 41
3.2.2 Chebyshev Lowpass Prototype Filters 41
3.2.3 Elliptic Function Lowpass Prototype Filters 44
3.2.4 Gaussian Lowpass Prototype Filters 46
3.2.5 All-Pass Lowpass Prototype Filters 47
3.3 Frequency and Element Transformations 48
3.3.1 Lowpass Transformation 49
3.3.2 Highpass Transformation 51
3.3.3 Bandpass Transformation 51
3.3.4 Bandstop Transformation 53
3.4 Immittance Inverters 54
3.4.1 Definition of Immittance, Impedance and Admittance Inverters 54
3.4.2 Filters with Immittance Inverters 56
3.4.3 Practical Realization of Immittance Inverters 60
3.5 Richards’Transformation and Kuroda Identities 61
3.5.1 Richards’Transformation 61
3.5.2 Kuroda Identities 66
3.5.3 Coupled-Line Equivalent Circuits 66
3.6 Dissipation and Unloaded Quality Factor 69
3.6.1 Unloaded Quality Factors of Lossy Reactive Elements 70
3.6.2 Dissipation Effects on Lowpass and Highpass Filters 71
3.6.3 Dissipation Effects on Bandpass and Bandstop Filters 73
References 75
4. Transmission Lines and Components 77
4.1 Microstrip Lines 77
4.1.1 Microstrip Structure 77
4.1.2 Waves in Microstrip 77
4.1.3 Quasi-TEM Approximation 78
4.1.4 Effective Dielectric Constant and Characteristic Impedance 78
4.1.5 Guided Wavelength, Propagation Constant, Phase
4.1.5 Velocity, and Electrical Length 80
4.1.6 Synthesis of W/h 80
4.1.7 Effect of Strip Thickness 81
4.1.8 Dispersion in Microstrip 82
4.1.9 Microstrip Losses 83
4.1.10 Effect of Enclosure 84
4.1.11 Surface Waves and Higher-Order Modes 84
4.2 Coupled Lines 84
4.2.1 Even- and Odd-Mode Capacitances 85
4.2.2 Even- and Odd-Mode Characteristic Impedances and Effective
4.1.5 Dielectric Constants 87
4.2.3 More Accurate Design Equations 87
4.3 Discontinuities and Components 89
4.3.1 Microstrip Discontinuities 89
4.3.2 Microstrip Components 93
4.3.3 Loss Considerations for Microstrip Resonators 102
4.4 Other Types of Microstrip Lines 104
References 106
5. Lowpass and Bandpass Filters 109
5.1 Lowpass Filters 109
5.1.1 Stepped-Impedance L-C Ladder Type Lowpass Filters 109
5.1.2 L-C Ladder Type of Lowpass Filters using Open-Circuited Stubs 112
5.1.3 Semilumped Lowpass Filters Having Finite-Frequency
5.1.3 Attenuation Poles 116
5.2 Bandpass Filters 121
5.2.1 End-Coupled, Half-Wavelength Resonator Filters 121
5.2.2 Parallel-Coupled, Half-Wavelength Resonator Filters 127
5.2.3 Hairpin-Line Bandpass Filters 129
5.2.4 Interdigital Bandpass Filters 133
5.2.5 Combline Filters 142
5.2.6 Pseudocombline Filters 148
5.2.7 Stub Bandpass Filters 151
References 158
6. Highpass and Bandstop Filters 161
6.1 Highpass Filters 161
6.1.1 Quasilumped Highpass Filters 161
6.1.2 Optimum Distributed Highpass Filters 165
6.2 Bandstop Filters 168
6.2.1 Narrow-Band Bandstop Filters 168
6.2.2 Bandstop Filters with Open-Circuited Stubs 176
6.2.3 Optimum Bandstop Filters 182
6.2.4 Bandstop Filters for RF Chokes 188
References 190
7. Advanced Materials and Technologies 191
7.1 Superconducting Filters 191
7.1.1 Superconducting Materials 191
7.1.2 Complex Conductivity of Superconductors 192
7.1.3 Penetration Depth of Superconductors 193
7.1.4 Surface Impedance of Superconductors 194
7.1.5 Nonlinearity of Superconductors 197
7.1.6 Substrates for Superconductors 199
7.1.7 HTS Microstrip Filters 200
7.1.8 High-Power HTS Filters 201
7.2 Ferroelectric Tunable Filters 204
7.2.1 Ferroelectric Materials 205
7.2.2 Dielectric Properties 206
7.2.3 Tunable Microstrip Filters 208
7.3 Micromachined Filters 211
7.3.1 MEMS and Micromachining 211
7.3.2 Micromachined Microstrip Filters 211
7.4 MMIC Filters 215
7.4.1 MMIC Technology 215
7.4.2 MMIC Microstrip Filters 216
7.5 Active Filters 217
7.5.1 Active Filter Methodologies 217
7.5.2 Active Microstrip Filters 219
7.6 Photonic Bandgap (PBG) Filters 221
7.6.1 PBG Structures 221
7.6.2 PBG Microstrip Filters 222
7.7 Low-Temperature Cofired Ceramic (LTCC) Filters 224
7.7.1 LTCC Technology 224
7.7.2 Miniaturized LTCC Filters 225
References 227
8. Coupled Resonator Circuits 235
8.1 General Coupling Matrix for Coupled-Resonator Filters 236
8.1.1 Loop Equation Formulation 236
8.1.2 Node Equation Formulation 240
8.1.3 General Coupling Matrix 243
8.2 General Theory of Couplings 244
8.2.1 Synchronously Tuned Coupled-Resonator Circuits 245
8.2.2 Asynchronously Tuned Coupled-Resonator Circuits 251
8.3 General Formulation for Extracting Coupling Coefficient k 257
8.4 Formulation for Extracting External Quality Factor Qe 258
8.4.1 Singly Loaded Resonator 259
8.4.2 Doubly Loaded Resonator 262
8.5 Numerical Examples 264
8.5.1 Extracting k (Synchronous Tuning) 265
8.5.2 Extracting k (Asynchronous Tuning) 267
8.5.3 Extracting Qe 270
References 271
9. CAD for Low-Cost and High-Volume Production 273
9.1 Computer-Aided Design Tools 274
9.2 Computer-Aided Analysis 274
9.2.1 Circuit Analysis 274
9.2.2 Electromagnetic Simulation 279
9.2.3 Artificial Neural Network Modeling 283
Microstrip Filters for Mobile Communicaitons application Content.pdf
106.47 KB, 下载次数: 50 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Content
 楼主| 发表于 2007-1-18 10:49:53 | 显示全部楼层
Microstrip Filters for Mobile Communicaitons application_CH1.pdf
80.47 KB, 下载次数: 28 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CH1
 楼主| 发表于 2007-1-18 10:50:58 | 显示全部楼层
Microstrip Filters for Mobile Communicaitons application_CH2.pdf
227.4 KB, 下载次数: 25 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CH2
 楼主| 发表于 2007-1-18 10:52:17 | 显示全部楼层
Microstrip Filters for Mobile Communicaitons application_CH3.pdf
705.63 KB, 下载次数: 31 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CH3
 楼主| 发表于 2007-1-18 10:53:10 | 显示全部楼层
Microstrip Filters for Mobile Communicaitons application_CH4.pdf
325.14 KB, 下载次数: 27 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CH4
 楼主| 发表于 2007-1-18 10:55:50 | 显示全部楼层
Microstrip Filters for Mobile Communicaitons application_CH5.pdf
992.48 KB, 下载次数: 28 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CH5
 楼主| 发表于 2007-1-18 10:57:23 | 显示全部楼层
Microstrip Filters for Mobile Communicaitons application_CH6.pdf
548.83 KB, 下载次数: 25 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CH6
 楼主| 发表于 2007-1-18 10:58:44 | 显示全部楼层
Microstrip Filters for Mobile Communicaitons application_CH7.pdf
1.26 MB, 下载次数: 25 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CH7
 楼主| 发表于 2007-1-18 11:01:18 | 显示全部楼层
Microstrip Filters for Mobile Communicaitons application_CH8.pdf
533.75 KB, 下载次数: 25 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CH8
 楼主| 发表于 2007-1-18 11:02:34 | 显示全部楼层
Microstrip Filters for Mobile Communicaitons application_CH9.pdf
889.93 KB, 下载次数: 32 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CH9
GMT+8, 2025-12-16 03:45 , Processed in 0.026574 second(s), 6 queries , Gzip On, Redis On.
