楼主: mabas.masood
hfss 14 linux [cracked]
发表于 2013-6-12 12:24:58 | 显示全部楼层
回复 7# mabas.masood
先谢谢楼主,下载了。不过怎么安装呢?
我下载后解压到了这里:
/opt/edasoft/download/hfss/hfss14.0/Linux
然后运行./hfss,会提示如下错误。
edasoft@edaserver:~/download/hfss/hfss14.0/Linux$ ./hfss
*** Error: Unable to determine binary that this wrapper should
           execute.  Please verify that this script is linked
           to an understood script name.
我没有按照ANSOFT的其它工具,单独安装HFSS可以吗?
 楼主| 发表于 2013-6-13 13:33:54 | 显示全部楼层
回复 11# etherguru
extract to /opt/ansoft
发表于 2013-6-13 16:33:23 | 显示全部楼层
回复 13# mabas.masood
   I extract to the path like you said, and I also find some error
how to deal with it? My OS is Red hat AS4
发表于 2013-6-13 16:36:16 | 显示全部楼层
回复 5# mabas.masood
   does the hfss packages only run in x64 platform? I found that it had a folder named ansoftbin64.
 楼主| 发表于 2013-6-13 17:01:09 | 显示全部楼层
yes you cant run hfss Linux in 32 bit
ansoft has discontinued supporting 32bit linux
发表于 2013-6-14 19:13:46 | 显示全部楼层
回复 13# mabas.masood
解压到/opt/ansoft仍然是一样的错误。楼主将你上传的安装包测试一下,给个安装说明好吗?
 楼主| 发表于 2013-6-15 02:57:54 | 显示全部楼层
you can't run this soft in redhat 4 or 5 you must run in redhat 6
发表于 2013-6-15 07:35:53 | 显示全部楼层
hi ,mabas.masood .
Thanks you for share the hfss(with cracked) for linux software.
I test it on Redhat EL 5.7(X64 platform).
It's only work one time is ok!
Other test is hang at:  connector-HFSSDesign1-Setup1:Marking Initial Mesh on Local
发表于 2013-6-17 14:00:19 | 显示全部楼层
Thanks, mabas.masood.
1. I had download these *.rar files and extracted them in PC.
2. After uploaded to workstation, I rebuilt some symbolic link=====
.exewrapper -> .answrapper
.runtimebinwrapper -> .answrapper
.runtimeclassicexewrapper -> .answrapper
.runtimeexewrapper -> .answrapper
.runtimepathwrapper -> .answrapper
HFIECOMENGINE -> .runtimeclassicexewrapper
HFSSCOMENGINE -> .runtimeclassicexewrapper
OPTICOMENGINE -> .runtimeclassicexewrapper
UpdateRegistry -> .exewrapper
ansoftrsm -> .runtimebinwrapper
desktopjob -> .runtimebinwrapper
desktopproxy -> .runtimebinwrapper
djobextractor -> .runtimebinwrapper
hfss -> .runtimeexewrapper
mwcontrol -> .runtimepathwrapper
plotdata -> .runtimebinwrapper
pm2ansoft -> .runtimeclassicexewrapper
To run it over CentOS 5.8 and it can start the interface properly without complain about
but it complain about the license issue. Is there something I can do to fix that issue ?
发表于 2013-6-19 21:22:50 | 显示全部楼层
还得学linux,不会用啊
GMT+8, 2025-12-19 06:51 , Processed in 0.024720 second(s), 6 queries , Gzip On, Redis On.
