查看: 13133|回复: 33
[转贴] JSSC 2013 06
发表于 2013-5-23 11:25:21 | 显示全部楼层 |阅读模式
JSSC 2013 06.part1.rar (15 MB , 下载次数: 1690 )
JSSC 2013 06.part2.rar (8.69 MB , 下载次数: 1156 )
目录:
Full-Duplex Crystalless CMOS Transceiver With an On-Chip Antenna for Wireless Communication in a Hybrid Engine Controller Board
Tunable N-Path Notch Filters for Blocker Suppression:Modeling and Verification
A 12-Gb/s Multichannel I/O Using MIMO Crosstalk Cancellation and Signal Reutilization in 65-nm CMOS
Clock Multiplication Techniques Using Digital Multiplying Delay-Locked Loops
A 6-b 4.1-GS/s Flash ADC With Time-Domain Latch Interpolation in 90-nm CMOS
A 10-b 1-GHz 33-mW CMOS ADC
A Resolution-Reconfigurable 5-to-10-Bit 0.4-to-1 V Power Scalable SAR ADC for Sensor Applications
An Orthogonal Current-Reuse Amplifier for Multi-Channel Sensing
A Low-Power DCVSL-Like GIDL-Free Voltage Driver for Low-Cost RFID Nonvolatile Memory
1.2-V Supply, 100-nW, 1.09-V Bandgap and 0.7-V Supply, 52.5-nW, 0.55-V Subbandgap Reference Circuits for Nanowatt CMOS LSIs
Correction to “A 0.016 mm2 144-μW Three-Stage Amplifier Capable of Driving 1-to-15 nF Capacitive Load With >0.95-MHz GBW”
下面这篇我一直下载不了,等我弄到了再补上吧:
A 10-b Two-Stage DAC with an Area-Efficient Multiple-Output Voltage Selector and a Linearity-Enhanced DAC-Embedded Op-Amp for LCD Column Driver ICs
 楼主| 发表于 2013-5-23 11:36:28 | 显示全部楼层
提供每篇文章的单独下载,跟上面打包的文件是一样的
abbr_507fdd8cda20d0ec0d2e58fbd676d088.pdf (1.4 MB , 下载次数: 6 )
A 6-b 4.1-GS/s Flash ADC With Time-Domain Latch Interpolation in 90-nm CMOS.pdf (2.82 MB , 下载次数: 30 )
A 10-b 1-GHz 33-mW CMOS ADC.pdf (1.76 MB , 下载次数: 52 )
abbr_05e62435cc93be09121c87cb277271eb.pdf (4.12 MB , 下载次数: 6 )
A Low-Power DCVSL-Like GIDL-Free Voltage Driver for Low-Cost RFID Nonvolatile Memory.pdf (3.53 MB , 下载次数: 6 )
abbr_34e1925ed9926f420f9f5c71e859d680.pdf (2.34 MB , 下载次数: 17 )
An Orthogonal Current-Reuse Amplifier for Multi-Channel Sensing.pdf (1.99 MB , 下载次数: 5 )
Clock Multiplication Techniques Using Digital Multiplying Delay-Locked Loops.pdf (2.97 MB , 下载次数: 17 )
abbr_a1561bb286026ea438db37d32d69319f.pdf (113.91 KB , 下载次数: 7 )
abbr_8e522cbaf4d6f2e958dd85db837473b3.pdf (3.36 MB , 下载次数: 14 )
Tunable N-Path Notch Filters for Blocker Suppression:Modeling and Verification.pdf (2.07 MB , 下载次数: 5 )
发表于 2013-5-23 11:54:20 | 显示全部楼层
太厚道了
发表于 2013-5-23 12:05:19 | 显示全部楼层
lz辛苦了,支持一下!
发表于 2013-5-23 14:14:32 | 显示全部楼层
辛苦了
发表于 2013-5-23 17:54:49 | 显示全部楼层
发表于 2013-5-24 08:29:28 | 显示全部楼层
貌似缺了不少啊。麻烦楼主补齐,谢谢!
发表于 2013-5-27 10:10:21 | 显示全部楼层
有誰補一個完整版的嗎?
 楼主| 发表于 2013-5-27 15:26:12 | 显示全部楼层
20130527 补充
上次IEEE网站上的文章还没更新完我就发帖了,现在把剩下的部分补全。
JSSC 2013 06_1.part1.rar (15 MB , 下载次数: 1099 )
JSSC 2013 06_1.part2.rar (1.43 MB , 下载次数: 127 )
这次上传的两个附件中的文章包括:
A 1 Mb Nonvolatile Embedded Memory Using 4T2MTJ Cell With 32 b Fine-Grained Power Gating Scheme
A Bang-Bang Clock and Data Recovery Using Mixed Mode Adaptive Loop Gain Strategy
A High Layer Scalability TSV-Based 3D-SRAM With Semi-Master-Slave Structure and Self-Timed Differential-TSV for High-Performance Universal-Memory-Capacity-Platforms
A Low Power BAW Resonator Based 2.4-GHz Receiver With Bandwidth Tunable Channel Selection Filter at RF
A Second-Order ΔΣ ADC Using Noise-Shaped Two-Step Integrating Quantizer
Correction to “A 2 Gb/s Throughput CMOS Transceiver Chipset With In-Package Antenna for 60 GHz Short-Range Wireless Communication”
The Outphasing RF Power Amplifier: A Comprehensive Analysis and a Class-B CMOS Realization
Correction to “A Linearized, Low Phase Noise VCO Based 25 GHz PLL With Autonomic Biasing”
发表于 2013-5-27 21:36:29 | 显示全部楼层
多谢楼主!
GMT+8, 2025-10-29 07:11 , Processed in 0.023384 second(s), 5 queries , Gzip On, Redis On.
