查看: 5127|回复: 4
发个mcu的行为级模型(可用于做mcu相关的功能验证)
发表于 2007-1-12 21:07:51 | 显示全部楼层 |阅读模式
部分代码如下:【需要的话,请到本贴购买】
http://www.eetop.cn/bbs/viewthread.php?tid=39573&extra=page%3D1
`timescale 1 ns / 10 ps
//`define PCMCIA_TEST
//`define  SCI_TEST
`define  TSI_TEST
module mcu_model
input   sys_clk,
input   int,
input   avalon_req,
input  [63:0] cw,
input  [7:0] table_id,
input  [15:0] pid,
input  [4:0] index,
output reg [7:0] ts_ctrl,
output reg  mcu_cs,
output reg  mcu_wr,
output reg  mcu_rd,
input   mcu_ack,
output reg [15:0] mcu_addr,
output reg [7:0] mcu_wrdat,
input  [7:0] mcu_rddat
reg bus_busy=0;
//reg [7:0] ts_ctrl;
integer sec_ch0;
task mcu_write;
  input [15:0] wraddr;
  input [7:0] wrdat;
begin
  wait ( bus_busy == 1'b0 );
  bus_busy = 1'b1;
  @ ( posedge sys_clk )
  begin
   mcu_wr = 1'b0;
   mcu_cs = 1'b0;
   mcu_addr = wraddr;
   mcu_wrdat = wrdat;
  end
  begin
  // test demux buffer
  addr = 8'h00;
  for ( i=0; i<32; i=i+1 )
  begin
   mcu_write( {4'he,`demux_base,`pid_scope, 8'h00} , 8'hff );
   mcu_write( {4'he,`demux_base,`pid_scope, 8'h01} , 8'h1f|8'h60 );  // enable desc & sec
   mcu_write( {4'he,`demux_base,`pid_scope, 1'b1,2'b00, addr[4:0]} , 8'h01 ); // set PID
   addr = addr + 1'b1;
  end
  // configuation demux
  mcu_write( {4'he,`demux_base,`reg_scope, 8'h00} , 8'h01 ); //set alpas (msb) to be '0' and auto (lsb) to be '1'
  mcu_write( {4'he,`demux_base,`pid_scope, 8'h00} , 8'ha0 );
  mcu_write( {4'he,`demux_base,`pid_scope, 8'h01} , 8'h00 );
  mcu_write( {4'he,`demux_base,`pid_scope, 8'h85} , 8'h01 ); // channel 5, pid = 00a0
  ts_ctrl <= 8'h87;  // Tuner send enable
  # 200000;
  //$fsdbDumpflush;
//$finish();
end
`endif
endmodule
[ 本帖最后由 wice3 于 2007-1-12 21:40 编辑 ]
发表于 2011-2-22 16:11:17 | 显示全部楼层
mcu的行为级模型,好
发表于 2011-2-22 18:41:34 | 显示全部楼层
代碼不全
发表于 2011-2-22 18:59:27 | 显示全部楼层
看一下……
发表于 2011-3-19 18:37:35 | 显示全部楼层
代码虽然不全,但是有参考意义。
GMT+8, 2025-12-29 13:38 , Processed in 0.024739 second(s), 6 queries , Gzip On, Redis On.
