楼主: dscd1900
[求助] LDO 的 重要问题
发表于 2013-5-8 20:01:12 | 显示全部楼层
回复 19# hszgl
    vds_sat might change accordingly with Vgs but Vds is supposed to be not as long as LDO still has sufficient gain
发表于 2013-5-8 20:29:38 | 显示全部楼层
回复 19# hszgl
    服了你了
发表于 2013-5-9 11:41:46 | 显示全部楼层
回复 20# hszgl
    当EA的输出过高或者过低时,其增益会明显下降!你可以仿真一下EA的增益随其输出DC电压变化情况!是增益降低导致失调电压增加!
发表于 2013-5-9 12:05:32 | 显示全部楼层
回复 22# hezudao
    呵呵
发表于 2013-5-9 19:42:23 | 显示全部楼层
回复 23# fengchunyi_2011
   哦,这下我看懂了。我以为你说的是失调电压导致增益下降。。那就反了。。。
发表于 2013-5-9 19:49:35 | 显示全部楼层
回复 21# sh_nouvell
   不太理解,你能举个具体点的例子解释一下么?
发表于 2013-5-12 20:09:32 | 显示全部楼层
回复 26# hszgl
    i would say this is the fundamental characteristic of MOS device...you can find explanation in the 1st chapter of any IC design book...
发表于 2013-5-12 20:46:05 | 显示全部楼层
回复 27# sh_nouvell
    你说VGS变化的时候VDS可能不变我懂,但是我不理解的是在LDO的反馈回路里,怎么会出现pass transistor的VGS变化的情况呢?
发表于 2013-5-12 21:04:05 | 显示全部楼层
回复 28# hszgl
    In an LDO, the operation region of the pass transistor might be varying according to the loading , which is equivantly to say Vgs is varying. Yet Vds is not necessarily changed because it is regulated by the high gain loop. Thats why i said as long as the loop gain is still high enough, Vds could be the same.
发表于 2013-5-13 09:19:21 | 显示全部楼层
top的人还是挺耐心的,楼上说的很清楚了。
pmos可看成可变电阻,vgs是它的控制电压,因为反馈环路,vgs随外部条件变化而变化,使得drain电压保持在额定值。
GMT+8, 2025-12-22 19:20 , Processed in 0.022789 second(s), 4 queries , Gzip On, Redis On.
