查看: 13425|回复: 18
IC615在Centos6.3上安装问题
发表于 2013-4-30 10:27:31 | 显示全部楼层 |阅读模式
系统:Centos6.3 64位(已经yum update,但是由于更新后,新的内核2.6.32-359.6.1.e16在启动时黑屏,所以仍用的就内核2.6.32-279.e16)
Cadence: IC615 (来自http://bbs.eetop.cn/viewthread.php?tid=375244&highlight=ic615
在安装的过程中,提示出现需要若干32位的库,也进行了yum install. (http://bbs.eetop.cn/viewthread.php?tid=322992&highlight=ic615,但其中的libXest.so.6库yum没找到,安装过程中也没报错)
目前出现的问题见图片:
install正常,但是configure failed。没有出现教程中说的configure的界面,点击右下角的Done,则有回到安装界面。
如何解决,请达人指导啊,非常感谢。
configure failed
configure failed
发表于 2013-4-30 10:44:40 | 显示全部楼层
you must install xterm with this command
yum install xterm
 楼主| 发表于 2013-4-30 11:50:51 | 显示全部楼层
It is work. Thank you very much.
Can you tell me why?
发表于 2013-4-30 13:21:38 | 显示全部楼层
because cadence has been using xterm in configure and verilog(-a) editor.
xterm has  been existing in old version centos and redhat such as V4 and V5 but centos 6, xterm hasn't been in  typical install.
 楼主| 发表于 2013-5-1 16:53:51 | 显示全部楼层
I understand, Thank you very much!
 楼主| 发表于 2013-5-1 16:54:42 | 显示全部楼层
I understand.
 楼主| 发表于 2013-5-1 16:56:19 | 显示全部楼层
i understand.
thank you very much!
发表于 2014-3-16 12:33:00 | 显示全部楼层
very helpful,I encountered the same problem while install IC615 in centos6.5
thx alot!
发表于 2014-4-21 11:36:55 | 显示全部楼层
谢谢楼主 @ 大神的解决!!
发表于 2014-5-12 15:37:05 | 显示全部楼层
goooooood
GMT+8, 2025-12-27 17:35 , Processed in 0.052240 second(s), 7 queries , Gzip On, Redis On.
