查看: 3861|回复: 0
[求助] AMS仿真问题,晶体管级仿真出错~~~~
发表于 2013-4-23 11:01:41 | 显示全部楼层 |阅读模式
在做AD_SAR   理想模型已经建立,并且AMS仿真成功,波形正确。
想要用晶体管级的电路替代理想模型,现在只替代了开关而已,用的是0.5的库,st02
然后仿真出现这些问题,求大神指教~~~
ncelab: 05.60-p001: (c) Copyright 1995-2005 Cadence Design Systems, Inc.
ncelab: *W,DLNOHV: Unable to find an 'hdl.var' file to load in.
ncupdate: *W,DLNOHV: Unable to find an 'hdl.var' file to load in.
ncvlog: *W,DLNOHV: Unable to find an 'hdl.var' file to load in.
ncelab: *W,CUNOUN: Cannot find any unit under st02.mp:spectre in the design libraries.
ncelab: *E,CUCFUN: instance 'PM1' of the unit 'mp' is unresolved in 'AD_sar.sw_st02:schematic'.
ncelab: *E,CUCFUN: instance 'PM0' of the unit 'mp' is unresolved in 'AD_sar.sw_st02:schematic'.
ncelab: *W,CUNOUN: Cannot find any unit under st02.mn:spectre in the design libraries.
ncelab: *E,CUCFUN: instance 'NM1' of the unit 'mn' is unresolved in 'AD_sar.sw_st02:schematic'.
ncelab: *E,CUCFUN: instance 'NM0' of the unit 'mn' is unresolved in 'AD_sar.sw_st02:schematic'.
ncelab: Memory Usage - 13.7M program + 54.7M data = 68.4M total
ncelab: CPU Usage - 0.7s system + 0.3s user = 1.0s total (1.1s, 87.5% cpu)
GMT+8, 2025-12-14 18:39 , Processed in 0.013579 second(s), 5 queries , Gzip On, Redis On.
