查看: 1935|回复: 3
[求助] signalstorm和默认的time analysis有什么区别?
发表于 2013-3-27 18:18:12 | 显示全部楼层 |阅读模式
encounter中signalstorm和默认的time analysis有什么区别?谁更好?
 楼主| 发表于 2013-3-28 12:15:22 | 显示全部楼层
求大神指点下
 楼主| 发表于 2013-3-29 11:20:38 | 显示全部楼层
求指点
发表于 2013-3-29 15:59:31 | 显示全部楼层
这种东西UG上都有...
You can perform delay calculation at various stages of the design flow to continuously validate your timing. The Encounter® Digital Implementation System (EDI System) provides three delay calculator engines that you can use:
EDI System delay calculator engine
Used to provide quick delay calculation for design prototyping, optimization, and general timing analysis.
SignalStorm® delay calculator
Used to perform final delay calculation and timing analysis. SignalStorm provides better accuracy, can calculate multi-driver nets, and uses more advanced effective current source model (ESCM) modeling.
AAE delay calculator
Used to perform delay calculation, timing analysis, and signal integrity (SI) analysis.
GMT+8, 2025-12-25 00:22 , Processed in 0.017952 second(s), 4 queries , Gzip On, Redis On.
