查看: 2775|回复: 1
[求助] 求助大大们,Encounter做runQRC的时候出错啦!~
发表于 2013-3-22 16:10:57 | 显示全部楼层 |阅读模式
大大们,我用Encounter做post route opt的时候报错,在starrc的时候出现这个错误:
ERROR (EXTZTECH-321) : Error [input]: Layer poly: Layer with sub-conductors has non-constant bias.
Only constant bias is allowed in layers with sub-conductor layers. Check
the layer description in the ICT file.
大神们,这个是什么引起的呢??第一次用encounter,不懂呀!~
另外mapfile:
layer   POLY1 icecaps     poly
layer   M1    icecaps     metal1
layer   M2    icecaps     metal2
layer   M3    icecaps     metal3
layer   M4    icecaps     metal4
layer   M5    icecaps     metal5
layer   M6    icecaps     metal6
layer   TM1   icecaps     metal7
layer   TM2   icecaps     metal8
layer   ALPA  icecaps     alpa_inter
layer   CT    icecaps     polyCont
layer   V1    icecaps     via1
ICTfile:
conductor poly {
   min_spacing           5.7600E-02
   min_contact_poly_spacing   0.036
   min_width             3.6000E-02
   height                3.2200E-01
   thickness             8.3160E-02
   resistivity           1.1450E+01
   temp_tc1              1.6600E-03
   temp_tc2              -2.9500E-07
   gate_forming_layer    true
   layer_type gate
   wire_edge_enlargement_c {
     wee_widths  3.6000E-02
     wee_spacings 5.7600E-02
     wee_adjustments    0.0061
恳请赐教!~
 楼主| 发表于 2013-3-22 17:13:26 | 显示全部楼层
大家都说说呗。。。指导下呀!~
GMT+8, 2025-12-26 23:34 , Processed in 0.018679 second(s), 6 queries , Gzip On, Redis On.
