查看: 1595|回复: 0
[求助] DC和PT里的set_max_fanout含义不一样
发表于 2013-1-25 15:22:36 | 显示全部楼层 |阅读模式
DC userguide里写 set_max_fantout command sets the maximum allowable fanout load for the listed input ports
而PT userguide里居然写着 set_max_fanout command sets a maximum fanout load for specified output ports or design,但我在PT里man set_max_fanout_command里面讲的和DC上是一样的,是input port,这是怎么回事?难道是PT userguide写错了?
GMT+8, 2025-12-22 03:02 , Processed in 0.015519 second(s), 4 queries , Gzip On, Redis On.
