查看: 4308|回复: 1
[讨论] LEF文件转Frame View问题
发表于 2013-1-24 17:17:25 | 显示全部楼层 |阅读模式
1.自己做的库,用milkyway,先将GDS转成了CEL VIEW,
但是foundry提供的LEF文件转出问题了,提示
LEF NAMESCASESENSITIVE ON is inconsistent with library case sensitive OFF.
Calling LEF IN API exit handler..
The library already has via info attach file,
use[dbDeletelibattachedfile libid"via_info_attach_file"]
to remove via info attach file first
2,网上搜索要自己生成LEF文件,在extact的时候老是提示:ERROPORT type table is not defined
求解!
发表于 2013-3-7 10:05:29 | 显示全部楼层
dbSetPortTypes ,好像是这个命令,Astro 的UG里面有哈。
GMT+8, 2025-12-25 11:01 , Processed in 0.021426 second(s), 7 queries , Gzip On, Redis On.
