 发表于 2013-1-23 21:16:02
显示全部楼层
| MEtal text 不应该根据.tf的定义来,而应该根据the pin text layer in the gds. for example, the metal1 layer number is 10, and pin text data type is 20, you should put 10:20 for metal pin by text, and so on. you should have no pin directly on Poly.
 After abstract, you need load .db, and turn on "overwrite the port direction", then the ports direction will be same as defined in .db.
