查看: 8802|回复: 34
130nm ESD Protection Design with Embedded SCR Structure(2005)
发表于 2006-12-29 10:23:45 | 显示全部楼层 |阅读模式
ESD Protection Design for I/O Cells With Embedded
SCR Structure as Power-Rail ESD Clamp Device
in Nanoscale CMOS Technology
Ming-Dou Ker, Senior Member, IEEE, and Kun-Hsien Lin, Member, IEEE
Abstract
This paper presents a new electrostatic discharge
(ESD) protection design for input/output (I/O) cells with embedded
silicon-controlled rectifier (SCR) structure as power-rail
ESD clamp device in a 130-nm CMOS process. Two new embedded
SCR structures without latchup danger are proposed to be placed
between the input (or output) pMOS and nMOS devices of the
I/O cells. Furthermore, the turn-on efficiency of embedded SCR
can be significantly increased by substrate-triggered technique.
Experimental results have verified that the human-body-model
(HBM) ESD level of this new proposed I/O cells can be greater
than 5 kV in a 130-nm fully salicided CMOS process. By including
the efficient power-rail ESD clamp device into each I/O cell,
whole-chip ESD protection scheme can be successfully achieved
within a small silicon area of the I/O cell.
abbr_ structure as power-rail ESD clamp device in nanoscale CMOS technology.part1.rar
1.39 MB, 下载次数: 163 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-12-29 10:25:19 | 显示全部楼层
REFERENCES
[1] S. Voldman, “The state of the art of electrostatic discharge protection:
Physics, technology, circuits, design, simulation, and scaling,” IEEE J.
Solid-State Circuits, vol. 34, no. 9, pp. 1272–1282, Sep. 1999.
[2] A. Wang, On-Chip ESD Protection for Integrated Circuits. Boston,
MA: Kluwer, 2001.
[3] C. Duvvury, R. Rountree, and O. Adams, “Internal chip ESD phenomena
beyond the protection circuit,” IEEE Trans. Electron Devices, vol. 35,
no. 12, pp. 2133–2139, Dec. 1988.
[4] C. Johnson, T. J. Maloney, and S. Qawami, “Two unusual HBM ESD
failure mechanisms on a mature CMOS process,” in Proc. EOS/ESD
Symp., 1993, pp. 225–231.
[5] V. Puvvada and C. Duvvury, “A simulation study of HBM failure in an
internal clock buffer and the design issue for efficient power pin protection
strategy,” in Proc. EOS/ESD Symp., 1998, pp. 104–110.
[6] M.-D. Ker, “Whole-chip ESD protection design with efficient
VDD-to-VSS ESD clamp circuits for submicron CMOS VLSI,”
IEEE Trans. Electron Devices, vol. 46, no. 1, pp. 173–183, Jan. 1999.
[7] Electrostatic Discharge Sensitivity Testing—Human Body Model
(HBM)—Component Level, ESD Association Standard, Test Method
ESD STM5.1, 1998.
[8] A. Chatterjee and T. Polgreen, “A low-voltage triggering SCR for
on-chip ESD protection at output and input pads,” IEEE Trans. Electron
Devices, vol. 12, no. 1, pp. 21–22, Jan. 1991.
abbr_ structure as power-rail ESD clamp device in nanoscale CMOS technology.part2.rar
897.16 KB, 下载次数: 96 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-12-29 10:27:04 | 显示全部楼层
Index Terms
Electrostatic discharge (ESD), input/output (I/O)
cell, silicon controlled rectifier (SCR), power-rail ESD clamp device.
Ming-Dou Ker (S’92–M’94–SM’97)
发表于 2007-1-2 11:29:42 | 显示全部楼层
what? book or paper?
发表于 2007-1-3 10:44:04 | 显示全部楼层
发表于 2007-1-6 05:58:54 | 显示全部楼层
just paper
发表于 2007-1-6 21:29:52 | 显示全部楼层
发表于 2007-1-6 21:37:30 | 显示全部楼层
发表于 2007-1-8 00:27:42 | 显示全部楼层
发表于 2007-1-15 03:07:44 | 显示全部楼层
so many aspect of design need to be studied, very headaches
GMT+8, 2025-12-26 12:03 , Processed in 0.021607 second(s), 6 queries , Gzip On, Redis On.
