查看: 3043|回复: 3
[原创] 时钟谐波
发表于 2013-1-10 21:26:44 | 显示全部楼层 |阅读模式
一个中频采集板,时钟是62M,客户对1.24G和1.302G两个频点的干扰很敏感,在板子调试的过程中,发现地上总是有很大的干扰(1.24G有-69dB,而在1.302G上有-80dBm左右
发表于 2013-7-13 11:51:59 | 显示全部楼层
在时钟输出端加滤波器抑制
发表于 2013-7-23 14:54:26 | 显示全部楼层
求好的解决方案
发表于 2013-8-2 12:20:17 | 显示全部楼层
really depends on what kind of coupling you get? Capacitor or Magnetic or even they share the same ground?
Capacitor is easy, add shielding,
Magnetic, probably you have a big current loop which mutually coupling to another loop, then you need to reduce loop area,
same ground: either separate or at least Kelvin connection
GMT+8, 2025-12-21 00:11 , Processed in 0.016432 second(s), 5 queries , Gzip On, Redis On.
