查看: 2669|回复: 3
[求助] 谁有XILINX DESIGN LANGUAGE 的资料?
发表于 2013-1-9 09:28:52 | 显示全部楼层 |阅读模式
想看看xdl格式的讲解
inst "n324aaaa" "SLICE",unplaced   ,
  cfg " BXINV::#OFF BXOUTUSED::#OFF BYINV::#OFF BYINVOUTUSED::#OFF BYOUTUSED::#OFF
       CEINV::#OFF CLKINV::#OFF COUTUSED::#OFF CY0F::#OFF CY0G::#OFF CYINIT::#OFF
       CYSELF::#OFF CYSELG::#OFF DIF_MUX::#OFF DIGUSED::#OFF DIG_MUX::#OFF
       DXMUX::#OFF DYMUX::#OFF F:U162bbbb:#LUT=((A1*A2)+(A3*A4)) F5USED::#OFF
       FFX::#OFF FFX_INIT_ATTR::#OFF FFX_SR_ATTR::#OFF FFY::#OFF FFY_INIT_ATTR::#OFF
       FFY_SR_ATTR::#OFF FXMUX::F FXUSED::#OFF F_ATTR::#OFF G:U165bbbb:#LUT=(~A1+~A2)
       GYMUX::G G_ATTR::#OFF REVUSED::#OFF SHIFTOUTUSED::#OFF SLICEWE0USED::#OFF
       SLICEWE1USED::#OFF SLICEWE2USED::#OFF SOPEXTSEL::#OFF SOPOUTUSED::#OFF
       SRFFMUX::#OFF SRINV::#OFF SYNC_ATTR::#OFF WF1USED::#OFF WF2USED::#OFF
       WF3USED::#OFF WF4USED::#OFF WG1USED::#OFF WG2USED::#OFF WG3USED::#OFF
       WG4USED::#OFF XBMUX::#OFF XUSED::0 YBMUX::#OFF YBUSED::#OFF YUSED::0
比如这个,我只看懂了LUT。
slice里面其他的东西,比如mux或者latch。使用的话,语法是什么样的?
发表于 2013-1-9 17:38:19 | 显示全部楼层
回复 1# 284294022
Xilinx ISE里Help有部分讲FPGA edit的内容,里面有介绍LUT中的逻辑表达式。其它的东西没仔细看,可以去查查。
 楼主| 发表于 2013-1-9 18:47:19 | 显示全部楼层
回复 2# mymemory
   好像内容挺少。我需要手动配置一下slice里面的MUX,但是一直不知道怎么着手
发表于 2013-7-15 17:10:06 | 显示全部楼层
回复 3# 284294022
我也很久不用FPGA Edit了,连Xilinx的AE都不建议用。你可以打开一个已有的设计试试,不会用的时候再查查Manual。
GMT+8, 2025-12-20 13:11 , Processed in 0.013559 second(s), 3 queries , Gzip On, Redis On.
