查看: 4578|回复: 7
sentaurus2010安装问题求解啊
发表于 2013-1-2 16:47:59 | 显示全部楼层 |阅读模式
[root@localhost installer2.3]# st
***                         Sentaurus Workbench                          ***
***                          Version D-2010.03                           ***
***                        (1.6, ia32, linux_gnu)                        ***
***                       Copyright (C) 1994-2010                        ***
***                            Synopsys, Inc.                            ***
***  This software and the associated documentation are confidential     ***
***  and proprietary to Synopsys, Inc.  Your use or disclosure of this   ***
***  software is subject to the terms and conditions of a written        ***
***  license agreement between you, or your company, and Synopsys, Inc.  ***
0:43:31 (snpslmd) OUT: "swb_all" root@localhost.localdomain
0:43:31 (snpslmd) OUT: "swb-advanced_all" root@localhost.localdomain
Sentaurus Workbench::Tcl_Init failed: Error: Environment variables STROOT, STRELEASE not specified.
This probably means that TCAD was not installed properly.
0:43:31 (snpslmd) IN: "swb-advanced_all" root@localhost.localdomain
0:43:31 (snpslmd) IN: "swb_all" root@localhost.localdomain
发表于 2013-1-2 17:41:11 | 显示全部楼层
 楼主| 发表于 2013-1-2 17:59:59 | 显示全部楼层
谁知道什么原因啊
发表于 2013-1-6 13:34:44 | 显示全部楼层
那你就在环境变量里面制定STROOT呗
发表于 2013-1-29 14:19:59 | 显示全部楼层
在/etc/bashrc里设置STROOT为sentaurus的安装目录,如安装在/opt会有 /opt/synopsys/D_2010.03/tcad/D-2010.03/linux/bin/这样的地址。那么bashrc里头就该设置为:
export STROOT=/opt/synopsys/D_2010.03
export STRELEASE=D-2010.03
要注意STRELEASE是指sentaurus版本,D后面是短划线-而不是下划线_
发表于 2014-3-18 23:50:58 | 显示全部楼层
楼主,请问这个问题解决了没
发表于 2014-3-19 09:06:09 | 显示全部楼层
回复 4# zhaoshukun
   具体怎么设置,请明细下
发表于 2014-3-19 19:25:15 | 显示全部楼层
回复 2# snk88
    STROOT, STRELEASE,请问这两个怎么设置,我也遇到这个问题
GMT+8, 2025-12-18 19:57 , Processed in 0.018265 second(s), 6 queries , Gzip On, Redis On.
