查看: 7071|回复: 4
[求助] StarRC提取中刚开始出现了错误。
发表于 2016-6-20 16:12:30 | 显示全部楼层 |阅读模式
StarRC (TM)
             Copyright (c) 1999-2013 Synopsys, Inc.
                      All Rights Reserved
ExecName: /usr/synopsys/STARRC/amd64_starrc/bin/StarXtract
Version: H-2013.06-SP3
Built on: Oct 16 2013 23:41:12
Start Time: Mon Jun 20 16:12:07 2016
Host ............ shywlinux
xTractorName:/usr/synopsys/STARRC/amd64_starrc/bin/xTractor
Built on: Oct 16 2013 23:41:17
WARNING: Reference Library Inconsistent With Main Library
         Reference Library: /home/shyw/work/icc/mw/sc9tap_logic013_base_rvt (MWLIBP-300)
ERROR: Could not determine 'RUNSET' attach file location. Milkyway 'XTR' is incomplete. (SX-2225)
这个错误是啥原因导致的呢?
我的脚本如下:
* TechReport
MAGNIFICATION_FACTOR:1
MAGNIFY_DEVICE_PARAMS:NO
EXTRACT_VIA_CAPS:YES IGNORE_GATE_CONTACT_COUPLING
NETLIST_PASSIVE_PARAMS: YES
BLOCK: trng_0901
MILKYWAY_DATABASE: /home/shyw/work/icc/pr/trng_0901
MILKYWAY_EXTRACT_VIEW: YES
CASE_SENSITIVE: NO
MODE:400
TCAD_GRD_FILE: /home/shyw/starRC/StarRC_013G_1P6M_5Ic_1TMc_ALPA_MIM1fF_V2.6_0P/NXTGRD/StarRC_013G_1P6M_5Ic_1TMc_ALPA_MIM1fF_CMAX.nxtgrd
MAPPING_FILE:  /home/shyw/work/icc/tlu+/tluplus.map
EXTRACTION: RC
COUPLE_TO_GROUND: NO
POWER_EXTRACT: YES
SKIP_CELLS: !*
SKIP_PCELLS: *rf*
NETLIST_FILE: ./trng_0620.spef
NETLIST_FORMAT: SPEF
XREF:YES
TRANSLATE_RETAIN_BULK_LAYERS:YES
CELL_TYPEAYOUT
NET_TYPEAYOUT
刚开始学习starrc 不知道如何找错误。。。求各位大侠帮帮小弟哈
 楼主| 发表于 2016-6-20 16:14:48 | 显示全部楼层
回复 1# yi4105635
    顶起来
 楼主| 发表于 2016-6-20 16:20:55 | 显示全部楼层
回复 2# yi4105635
   来人帮帮看看哦
发表于 2023-11-27 10:26:18 | 显示全部楼层
请问这问题您解决了吗?我也遇到了。
发表于 2024-1-2 19:45:05 | 显示全部楼层
请问您现在解决了吗
GMT+8, 2025-12-17 08:22 , Processed in 0.023744 second(s), 5 queries , Gzip On, Redis On.
