查看: 5687|回复: 1
[讨论] A problem when INCISIVE used in post-simulation.
发表于 2012-12-28 23:45:52 | 显示全部楼层 |阅读模式
>Recently,when I used INCISIVE to simulate my a design,the post simultion could pass in 200MHz,but failed in 220MHz.
>The main differences are the frequence (220MHz & 200MHz) and the irun order.
>In the 200MHz post-simulation, the irun order had "-access  rwc" and
>In the 220MHz post-simulation, the irun  order had "-access rw",others are the same.
>So I had been in a pullze about the result between "-access rwc" and "-access rw" and the tool's options.
发表于 2016-5-27 01:45:59 | 显示全部楼层
i am also there
GMT+8, 2025-12-27 11:25 , Processed in 0.019973 second(s), 7 queries , Gzip On, Redis On.
