查看: 2761|回复: 2
Centos安装Calibre2011遇到如下问题,求高手指教,谢谢
发表于 2012-12-26 09:56:57 | 显示全部楼层 |阅读模式
calibre程序已经安装,license也已经生成,但是在运行patch2011时,产生下面的error,请问如何解决呢?
Linux machine : localhost
: Command not found.
set: Variable name must begin with a letter.
[total hits/matching patterns/non-matching patterns]
78% shared/lib/libcfiel_6error: failed to read+write: sfk - skipping
6617 files checked, 0 changed.
1 errors occurred.
会不会是因为我的机器有两个Mac地址产生的error呢?
发表于 2013-3-19 10:51:08 | 显示全部楼层
我也遇到同样的问题,好像是因为要把64和32位的patch一起破解才可以
发表于 2014-12-10 20:55:58 | 显示全部楼层
"0 changed" means crack failed.
GMT+8, 2025-12-22 01:15 , Processed in 0.015310 second(s), 4 queries , Gzip On, Redis On.
