查看: 16695|回复: 16
[求助] DC插入ICG问题
发表于 2012-12-11 11:11:57 | 显示全部楼层 |阅读模式
小弟今天用DC插入ICG,  RTL代码是 assign clk_out = clk_en & clk_in;
我用库里面的CKLN/CKLH*(带TEN, 库里面只有带TEN的ICG) ICG cell, 脚本是
set_clock_gating_style -sequential_cell latch \
                                  -positive_edge_logic {integrated:tcb018gbwp7twc_ccs/CKLNQD2BWP7T}
可是DC报错,
Error: The library cell CKLNQD2BWP7T specified for use as an integrated clock gating does not have the correct value for the clock_gating_integrated_cell attribute. The attribute required is latch_negedge.  (PWR-192)
哪位大大能帮忙看看哪里出了问题了吗? RTL代码不能这样写? 在线等......
 楼主| 发表于 2012-12-11 11:28:03 | 显示全部楼层
哪位大大能帮帮忙啊,急啊,CKLNQD2BWP7T 在库里面的feature是clock_gating_integrated_cell呀
发表于 2012-12-11 15:51:15 | 显示全部楼层
你command用的是上升沿,但是error information中提示说这个库单元支持下降沿。所以,是用选项的问题。
我没用过DC插,所以不清楚该怎么写。但是就看你这个命令和REPORT,应该是这么回事。你先改一下,再发REPORT出来看看。
 楼主| 发表于 2012-12-11 16:11:43 | 显示全部楼层
回复 3# sunrisewu
    sorry,  之前错误报告贴错了, command还是相同的command, 错误报告是,
Error: The library cell CKLNQD2BWP7T specified for use as an integrated clock gating does not have the correct value for the clock_gating_integrated_cell attribute. The attribute required is latch_posedge.  (PWR-192)
cell CKLNQD2BWP7T 的feature是
dc_shell> report_attribute tcb018gbwp7twc_ccs/CKLNQD2BWP7T
Report : Attribute
Design : CLK_GEN
Version: C-2009.06
Date   : Tue Dec 11 16:01:14 2012
Design          Object             Type      Attribute Name            Value
CKLNQD2BWP7T    CKLNQD2BWP7T       design    area                      41.708801
CKLNQD2BWP7T    CKLNQD2BWP7T       design    cell_footprint            cklnqd1bwp7t
CKLNQD2BWP7T    CKLNQD2BWP7T       design    cell_leakage_power        1.046000
CKLNQD2BWP7T    CKLNQD2BWP7T       design    clock_gating_integrated_cell
        latch_posedge_precontrol
CKLNQD2BWP7T    CKLNQD2BWP7T       design    has_pin_internal_power    true
CKLNQD2BWP7T    CKLNQD2BWP7T       design    ebst_processed            2
CKLNQD2BWP7T    CKLNQD2BWP7T       design    ebst_valid                true
CKLNQD2BWP7T    CKLNQD2BWP7T       design    function_id               unknown
CKLNQD2BWP7T    CKLNQD2BWP7T       design    function_class            unknown
CKLNQD2BWP7T    CKLNQD2BWP7T       design    cmog_class                unknown
CKLNQD2BWP7T    CKLNQD2BWP7T       design    multiple_output_gate      true
CKLNQD2BWP7T    CKLNQD2BWP7T       design    number_of_pins            4
CKLNQD2BWP7T    CKLNQD2BWP7T       design    has_receiver_mode         true
 楼主| 发表于 2012-12-11 16:19:27 | 显示全部楼层
回复 3# sunrisewu
    还有个问题,我即使不用ICG,DC也不能综合出latch+gate,所以我在想是不是RTL不能这样写?
发表于 2012-12-11 16:24:06 | 显示全部楼层
我们一般都是直接把ICG例化进来的。
 楼主| 发表于 2012-12-11 16:31:14 | 显示全部楼层
回复 6# sunrisewu
    啊,GOD,
    直接在RTL里例化
    CKLN*  U1 (......);  ?
发表于 2012-12-12 15:18:09 | 显示全部楼层
                                   -positive_edge_logic {[color=Red
你在命令里面指定为positive_edge_logic ,但是指定lib_cell的时候用的是下降沿的icg。其中一个改一下就好了。
发表于 2013-3-1 17:30:00 | 显示全部楼层
如果用 compile_ultra -gate_clock 去插入clock gating 的话,RTL 描述应该如下:
always@(negedge rst_n or posedge clk_in)
    if(!rst_n)
          A<=1'b0;
      else if(clk_en)
          A<=B;
DC 会自动帮你把DFF D端的clk_en信号移到CK端的门控。
如果你非要自己用“assign clk_out = clk_en & clk_in;” 加门控的话,需要先编译一遍,然后用
replace_clock_gates + 增量编译
替换掉这个门控
发表于 2015-11-10 10:08:43 | 显示全部楼层
icfb能给解决这个问题么
GMT+8, 2025-12-20 01:46 , Processed in 0.020689 second(s), 5 queries , Gzip On, Redis On.
