查看: 13061|回复: 26
[求助] DC 2012.06版,每次一开GUI就crash
发表于 2012-12-4 17:53:47 | 显示全部楼层 |阅读模式
请问大家有没有碰到过同样问题?
$> dc_shell -gui
或者
dc_shell> start_gui
都crash。几个SP版也是这样,真是怪了。
 楼主| 发表于 2012-12-4 23:46:38 | 显示全部楼层
回复 2# zhq415758192
    不开GUI,只用shell模式就没啥异常;一开GUI就crash。
发表于 2012-12-5 10:02:43 | 显示全部楼层
something wrong with CRACK????
My shell mode always crush with memory overflow
 楼主| 发表于 2012-12-5 13:13:29 | 显示全部楼层
回复 4# zhq415758192
dc_shell -gui,过一阵直接退出回到系统提示符:
  [~/temp]$ dc_shell -gui
                      Design Compiler Graphical
                            DC Ultra (TM)
                             DFTMAX (TM)
                         Power Compiler (TM)
                           DesignWare (R)
                           DC Expert (TM)
                         Design Vision (TM)
                          HDL Compiler (TM)
                         VHDL Compiler (TM)
                            DFT Compiler
                        Library Compiler (TM)
                         Design Compiler(R)
          Version G-2012.06-SP2 for RHEL64 -- Aug 31, 2012
               Copyright (c) 1988-2012 Synopsys, Inc.
This software and the associated documentation are confidential and
proprietary to Synopsys, Inc. Your use or disclosure of this software
is subject to the terms and conditions of a written license agreement
between you, or your company, and Synopsys, Inc.
Initializing...
[~/temp]$
 楼主| 发表于 2012-12-5 13:15:48 | 显示全部楼层
回复 4# zhq415758192
shell模式无异常。只是一开GUI,同样crash:
    [~/temp]$ dc_shell
                            DC Ultra (TM)
                             DFTMAX (TM)
                         Power Compiler (TM)
                           DesignWare (R)
                           DC Expert (TM)
                         Design Vision (TM)
                          HDL Compiler (TM)
                         VHDL Compiler (TM)
                            DFT Compiler
                         Design Compiler(R)
Initializing...
dc_shell> read_ddc -help
Usage: read_ddc    # Read one or more ddc files
        [-scenarios scenario_list]
                               (list of scenarios to be read from ddc file)
        [-active_scenarios active_scenario_list]
                               (list of scenarios to be made active)
        file_names             (Files to read)
dc_shell> list_lic
Licenses in use:
        Design-Compiler
1
dc_shell> start_gui
[~/temp]$
 楼主| 发表于 2012-12-5 13:18:31 | 显示全部楼层
补充:
1)老版本,包括2011.09,正常无此问题
2)同样2012.06版的icc,正常无此问题
发表于 2012-12-6 10:14:42 | 显示全部楼层
回复 8# 分特
   等待更新吧,这版本有问题,不过也有解决方法,而且不是一劳永逸的,等待更新吧
发表于 2012-12-6 13:25:23 | 显示全部楼层
楼主可以试试“dc_shell -64 -gui”,这种方式对于避免memory overflow有很好的效果
 楼主| 发表于 2012-12-6 17:37:39 | 显示全部楼层
    [~/temp]$ dc_shell -64bit -gui
                            DC Ultra (TM)
                             DFTMAX (TM)
                         Power Compiler (TM)
                           DesignWare (R)
                           DC Expert (TM)
                         Design Vision (TM)
                          HDL Compiler (TM)
                         VHDL Compiler (TM)
                            DFT Compiler
                         Design Compiler(R)
Initializing...
[~/temp]$
之前已经是RHEL64版本了。
发表于 2012-12-7 13:17:28 | 显示全部楼层
log,你把那个贴上来,大家才能debug
GMT+8, 2025-12-27 14:21 , Processed in 0.025428 second(s), 6 queries , Gzip On, Redis On.
