查看: 5127|回复: 4
[求助] ic615 64bit打开库的错误
发表于 2012-11-28 10:06:58 | 显示全部楼层 |阅读模式
求高手指教
我有一CMSC05的工艺库,在IC615 32bit下能正常显示,但是切换到IC615 64bit后出现以下问题:
*WARNING* (DB-270001): Pcell evaluation for CSMC05MS/pmos4/layout has the following error(s):
*WARNING* (DB-270002): ("eval" 0 t nil ("*Error* eval: undefined function" PasGetDeviceProps))
*WARNING* (DB-270003): Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster.
*WARNING* (DB-270001): Pcell evaluation for CSMC05MS/nmos4/layout has the following error(s):
*WARNING* (DB-270002): ("eval" 1 t nil ("*Error* eval: undefined function" PasGetDeviceProps))
*WARNING* (DB-270001): Pcell evaluation for CSMC05MS/ntap/layout has the following error(s):
*WARNING* (DB-270002): ("eval" 2 t nil ("*Error* eval: undefined function" PasGetDeviceProps))
*WARNING* (DB-270001): Pcell evaluation for CSMC05MS/ptap/layout has the following error(s):
*WARNING* (DB-270002): ("eval" 3 t nil ("*Error* eval: undefined function" PasGetDeviceProps))
以致库器件变形,求帮忙。
发表于 2015-1-28 19:11:28 | 显示全部楼层
回复 1# kulin0601
    你好我用ic616打开130pdk也是这个错误,单独在ciw中loadlibInit.il文件,它提示在在skill文件夹中打不开64bit内的pdkUnits.cxt,但我查看skill中没有64bit文件夹,只有一个pdkunits.ctx,我就自己建了一个路径将32的链接过来,但是就提示32的文件不能在64的平台打开,请问楼主的问题解决没有!
发表于 2019-11-25 22:08:04 | 显示全部楼层
你好,我现在遇到了和你一样的问题,能请教一下解决方法吗?
发表于 2019-11-25 22:10:29 | 显示全部楼层
xiaoquanic 发表于 2015-1-28 19:11
回复 1# kulin0601
发表于 2020-5-25 15:08:06 | 显示全部楼层
你好,我现在也遇到了这样的问题,请问需要怎么解决。万分感谢!!!
GMT+8, 2025-12-18 19:59 , Processed in 0.021590 second(s), 6 queries , Gzip On, Redis On.
