查看: 25330|回复: 41
OriginLab OriginPro v9.0 + Cracked
发表于 2012-11-18 11:32:26 | 显示全部楼层 |阅读模式
OriginLab OriginPro v9.0 Cracked
NOTE: This is the x86 version only, so stop bitching about the x64 release or do it yourself. ;)
Origin is a software application with tools for data analysis, quality graphing and programming.
Origin contains powerful tools for all of your
analytic needs, including peak analysis, curve
fitting, statistics, and signal processing. To make
data analysis more efficient, Origin supports many
common formats for importing data, and exporting
results. Multi-sheet workbooks and an integrated
Project Explorer help you organize your Origin
projects. Streamline your workflow by saving
workbooks as analysis templates for repeat use.
With over 70 built-in graph types, Origin makes it
easy to create and customize publication quality
graphs to suit your needs. Many popular contour, 2D,
and 3D graph types are supported, as are specialty
graphs such as windrose, stock (OHLC), ternary
(including ternary-contour), 2D vector and 3D
vector, and several statistical plots.
Origin includes two built-in programming languages:
Origin C, a C-based compiled language, and a
scripting language called LabTalkT. Use them to
automate graphing and analysis. Origin comes with an
Integrated Development Environment (IDE), Code
Builder , that makes it easy to write and debug your
own code. Origin is also an Automation Server for
users of VB, C++, C# and LabVIEW.
OriginPro offers all of the features of Origin, plus
extended analysis tools in the following areas:
* Peak Fitting
The Peak Analyzer tool in OriginPro provides the
additional capability of finding and fitting
multiple peaks in your spectra. Baseline anchor
points can be customized and fit with a suitable
fitting function, and the baseline fitting can be
included as part of the final peak fitting process.
A detailed Fit Control dialog is provided to control
all aspects of peak fitting including mixed peak
functions, peak centers and widths, sharing
parameters, and imposing bounds and linear
constraints on parameters. Graphical as well as
tabular results are generated as part of the final
fit report.
* Surface Fitting
OriginPro can fit a 3D surface to XYZ data points.
The surface and data points can be displayed
together, including droplines from the points to the
surface.
* Statistics
OriginPro expands on the statistical analysis
capabilities of Origin by providing additional tools
for Descriptive Statistics, Discrete Frequency
Counting, Normality Tests, Correlation Analysis,
One-way and Two-way Repeated Measures ANOVA,
Principal Component Analysis, Hierarchical Cluster
and Discriminant Analysis, many Nonparametric Tests
such as Friedman ANOVA and Two-Sample
Kolmogorov-Smirnov Test and Mann-Whitney Test,
Survival Analysis tools including Weibull Fit and
Cox Proportional Hazard Model, ROC Curves, and Power
and Sample Size Tests.
* Signal Processing
Advanced signal processing features in OriginPro
include Short-Time FFT (STFT), Hilbert Transform,
Coherence, 2D FFT and 2D FFT-based Filtering, 2D
Correlation, and Wavelet analysis.
* Image Handling
OriginPro offers more ways to handle your image
data, including alpha blending, pixel logic,
morphological filtering, and interpolated background
subtraction.
* Analytical Power
With so much analytical power, OriginPro is the
software of choice for those who want a single data
analysis and graphing solution.
New Features in Origin 9.0:
* 3D OpenGL Graphing
* 3D Parametric Function Plot
* Movie/Animation Creation
* Data Filter
* Graphing Improvements
* Floating Graphs in Worksheet
* Global Vertical Cursor
* Implicit Function Fitting
* IIR Filter Design
Always remember to block applications (or go off line) from calling
home 'during install'. Once installed, disable 'check for automatic
updates' option if available, so that you don't get it blacklisted.
OriginLab OriginPro v9.0.part01.rar
15 MB, 下载次数: 186 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part02.rar
15 MB, 下载次数: 548 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part03.rar
15 MB, 下载次数: 223 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part04.rar
15 MB, 下载次数: 213 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part05.rar
15 MB, 下载次数: 262 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part06.rar
15 MB, 下载次数: 263 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part07.rar
15 MB, 下载次数: 246 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part08.rar
15 MB, 下载次数: 181 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part09.rar
OriginLab OriginPro v9.0.part10.rar
15 MB, 下载次数: 175 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part11.rar
15 MB, 下载次数: 172 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part12.rar
15 MB, 下载次数: 197 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part13.rar
15 MB, 下载次数: 193 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part14.rar
15 MB, 下载次数: 151 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part15.rar
OriginLab OriginPro v9.0.part16.rar
15 MB, 下载次数: 163 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part17.rar
15 MB, 下载次数: 195 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part18.rar
15 MB, 下载次数: 174 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part19.rar
15 MB, 下载次数: 165 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part20.rar
15 MB, 下载次数: 158 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part21.rar
15 MB, 下载次数: 392 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part22.rar
15 MB, 下载次数: 144 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part23.rar
OriginLab OriginPro v9.0.part24.rar
15 MB, 下载次数: 141 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part25.rar
15 MB, 下载次数: 139 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part26.rar
15 MB, 下载次数: 146 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part27.rar
15 MB, 下载次数: 145 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part28.rar
15 MB, 下载次数: 152 , 下载积分: 资产 -5 信元, 下载支出 5 信元
OriginLab OriginPro v9.0.part29.rar
10.08 MB, 下载次数: 149 , 下载积分: 资产 -4 信元, 下载支出 4 信元
发表于 2012-11-18 11:56:22 | 显示全部楼层
大版本升级,一定要试试!谢谢楼主!
 楼主| 发表于 2012-11-18 12:46:00 | 显示全部楼层
crack file only
Crack.rar
2.96 MB, 下载次数: 305 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2012-11-18 15:37:16 | 显示全部楼层
不错,又有更新了,喜欢Origin,专业!!!
发表于 2012-11-18 17:49:09 | 显示全部楼层
这个必须得顶!
楼主将crack单放出来!谢谢!
发表于 2012-11-18 20:05:08 | 显示全部楼层
very good, nice work
发表于 2012-11-18 21:58:36 | 显示全部楼层
发表于 2012-11-19 13:29:11 | 显示全部楼层
回复 1# hi_china59
    能单独发布Cr吗?
发表于 2012-11-20 21:09:41 | 显示全部楼层
偶尔用用,试问楼主,是汉化版么?
发表于 2012-11-23 20:42:38 | 显示全部楼层
Could not be located in COcontour9.dll
GMT+8, 2025-12-16 15:40 , Processed in 0.028899 second(s), 7 queries , Gzip On, Redis On.
