查看: 5089|回复: 6
[求助] assura 安装问题~请高手帮忙解决
发表于 2012-11-16 15:52:43 | 显示全部楼层 |阅读模式
[ CDROM1]$ ./SETUP.SH
Copyright 1985-2006 by Cadence Design Systems Inc.
LICENSED SOFTWARE - REVERSE ASSEMBLY, REVERSE COMPILATION AND
REVERSE ENGINEERING PROHIBITED. The information contained in
this package is the proprietary property of Cadence Design Systems,
Inc., or its licensors, and may only be used in accordance with
the Cadence Design Systems license agreement under which this
package is provided.
Restricted Rights Notice to Government Users
Use duplication or disclosure by the Government is subject to
the restrictions as set forth in subparagraphs (c)(1)(ii) of the
Rights in Technical Data and Computer Software clause at
DFARS 252.227-7013. Unpublished - all rights reserved under the
copyright laws of the United States.
Cadence Design Systems, Inc.
555 River Oaks Parkway
San Jose, California 95134 USA
Located CDROM at /assura1/ASSURA317-5141_lnx86.Base/CDROM1
Specify path of install directory [OR type [RETURN] to exit]: /assura
Detecting  InstallScape for lnx86...
Checking InstallScape on media...
./SETUP.SH: line 579: uncompress: command not found
/bin/tar: ./iscape/VERSION.lnx86: Not found in archive
/bin/tar: Error exit delayed from previous errors
/bin/cat: /tmp/is10846/iscape/VERSION.lnx86: No such file or directory
Could not detect an InstallScape for lnx86 platform using the  PATH environment variable
It is a good idea to have only one Installation of InstallScape
for lnx86 platform. If an InstallScape installation exists
please help us find it.
Do you have InstallScape for lnx86 platform installed somewhere [y/n]?
 楼主| 发表于 2012-11-16 15:54:40 | 显示全部楼层
出现这种问题是什么情况?请高手来支招~~
 楼主| 发表于 2012-11-16 16:01:04 | 显示全部楼层
顶上~在线等待高手支招
 楼主| 发表于 2012-11-21 09:55:19 | 显示全部楼层
楼上的有InstallScape的安装工具么?能否发一份过来~谢谢~
发表于 2012-11-24 10:55:37 | 显示全部楼层
去我网盘下吧 :http://www.kuaipan.cn/file/id_55286816193909915.htm
 楼主| 发表于 2012-12-1 08:52:19 | 显示全部楼层
如何将assura嵌入进cadence中?
GMT+8, 2025-12-22 04:45 , Processed in 0.018932 second(s), 5 queries , Gzip On, Redis On.
