楼主: Gary.wang
[求助] 关于lib里面DFF的setup time和hold time!!!
发表于 2012-11-4 11:50:52 | 显示全部楼层
cell (DFFHQX1) {
  cell_footprint : dffhq;
  area : 53.222400;
  pin(D) {
    direction : input;
    capacitance : 0.002193;
    internal_power() {
      rise_power(passive_energy_template_1x7) {
        index_1 ("0.025, 0.08, 0.3, 0.7, 1.2, 1.7, 2.3");
        values ("0.046422, 0.047950, 0.051254, 0.065027, 0.084779, 0.102433, 0.124810");
      fall_power(passive_energy_template_1x7) {
        values ("0.052953, 0.051399, 0.056175, 0.069996, 0.090363, 0.108792, 0.131087");
    timing() {
      related_pin : "CK";
      timing_type : setup_rising;
      rise_constraint(setup_template_3x3) {
        index_1 ("0.025, 0.7, 2.3");
        index_2 ("0.025, 0.7, 1.7");
        values ( \
          "0.066406, 0.082031, 0.183594", \
          "0.042969, 0.054688, 0.160156", \
          "-0.128906, -0.109375, 0.007812");
      fall_constraint(setup_template_3x3) {
        values ( \
          "0.136719, 0.148438, 0.382812", \
          "0.289062, 0.300781, 0.519531", \
          "0.632812, 0.644531, 0.875000");
    timing() {
      related_pin : "CK";
      timing_type : hold_rising;
      rise_constraint(hold_template_3x3) {
        values ( \
          "-0.031250, -0.066406, -0.164062", \
          "-0.007812, -0.031250, -0.136719", \
          "0.179688, 0.152344, 0.035156");
      fall_constraint(hold_template_3x3) {
        values ( \
          "-0.031250, -0.031250, -0.105469", \
          "-0.183594, -0.171875, -0.238281", \
          "-0.500000, -0.484375, -0.535156");
  pin(CK) {
    direction : input;
    clock : true;
    capacitance : 0.003057;
    internal_power() {
        values ("0.031776, 0.034143, 0.041185, 0.062110, 0.088720, 0.115901, 0.148819");
        values ("0.042751, 0.044956, 0.054208, 0.073618, 0.100675, 0.128054, 0.160988");
    min_pulse_width_high : 0.075230;
    min_pulse_width_low : 0.114046;
  ff(IQ,IQN) {
    clocked_on : "CK";
    next_state : "D";
  pin(Q) {
    direction : output;
    capacitance : 0.0;
    function : "IQ";
    internal_power() {
      related_pin : "CK";
      rise_power(energy_template_7x7) {
        index_2 ("0.00035, 0.021, 0.0385, 0.084, 0.147, 0.231, 0.3115");
        values ( \
          "0.033199, 0.033746, 0.032558, 0.030537, 0.027979, 0.024713, 0.021577", \
          "0.032740, 0.034635, 0.033725, 0.031806, 0.029280, 0.026016, 0.022889", \
          "0.034468, 0.035408, 0.035415, 0.033527, 0.031093, 0.027857, 0.024743", \
          "0.038458, 0.032936, 0.032171, 0.033302, 0.030833, 0.027592, 0.024479", \
          "0.040797, 0.036192, 0.035824, 0.033104, 0.031157, 0.028073, 0.024993", \
          "0.038872, 0.036537, 0.036396, 0.033005, 0.030987, 0.028233, 0.025296", \
          "0.041415, 0.038962, 0.038802, 0.038611, 0.029142, 0.026985, 0.024677");
      fall_power(energy_template_7x7) {
        values ( \
          "0.024088, 0.031324, 0.031560, 0.031364, 0.031213, 0.031180, 0.031194", \
          "0.023695, 0.030670, 0.030803, 0.030621, 0.030534, 0.030489, 0.030488", \
          "0.030855, 0.031924, 0.032135, 0.031890, 0.031750, 0.031676, 0.031637", \
          "0.037953, 0.034213, 0.033739, 0.033826, 0.033687, 0.033602, 0.033558", \
          "0.042105, 0.039090, 0.038503, 0.037979, 0.037665, 0.037523, 0.037468", \
          "0.044159, 0.040718, 0.039992, 0.039392, 0.039036, 0.038811, 0.038758", \
          "0.048419, 0.043883, 0.042796, 0.042105, 0.041782, 0.041566, 0.041461");
    timing() {
      related_pin : "CK";
      timing_type : rising_edge;
      timing_sense : non_unate;
      cell_rise(delay_template_7x7) {
        values ( \
          "0.126573, 0.193260, 0.248096, 0.390868, 0.588802, 0.852752, 1.105708", \
          "0.134473, 0.201174, 0.255999, 0.398774, 0.596707, 0.860664, 1.113618", \
          "0.145903, 0.212583, 0.267436, 0.410202, 0.608148, 0.872110, 1.125078", \
          "0.136173, 0.202878, 0.257670, 0.400448, 0.598397, 0.862369, 1.115346", \
          "0.106654, 0.173379, 0.228159, 0.370874, 0.568808, 0.832793, 1.085774", \
          "0.068813, 0.135429, 0.190210, 0.332876, 0.530788, 0.794767, 1.047748", \
          "0.017292, 0.083994, 0.138722, 0.281356, 0.479233, 0.743198, 0.996177");
      rise_transition(delay_template_7x7) {
        values ( \
          "0.027426, 0.139885, 0.239102, 0.498684, 0.858777, 1.338964, 1.799138", \
          "0.027074, 0.139903, 0.239145, 0.498683, 0.858781, 1.338962, 1.799146", \
          "0.027321, 0.139903, 0.239034, 0.498673, 0.858772, 1.338957, 1.799135", \
          "0.027371, 0.139905, 0.239140, 0.498719, 0.858770, 1.338958, 1.799132", \
          "0.027538, 0.139925, 0.239117, 0.498658, 0.858797, 1.338970, 1.799139", \
          "0.027138, 0.139912, 0.239130, 0.498635, 0.858748, 1.338958, 1.799150", \
          "0.027804, 0.139953, 0.239140, 0.498599, 0.858731, 1.338930, 1.799137");
      cell_fall(delay_template_7x7) {
        values ( \
          "0.108444, 0.168458, 0.207951, 0.301866, 0.428812, 0.597802, 0.759784", \
          "0.115862, 0.175926, 0.215418, 0.309339, 0.436289, 0.605282, 0.767266", \
          "0.126392, 0.186308, 0.225761, 0.319692, 0.446633, 0.615625, 0.777607", \
          "0.115838, 0.175857, 0.215357, 0.309273, 0.436185, 0.605165, 0.767136", \
          "0.085674, 0.146090, 0.185647, 0.279622, 0.406554, 0.575510, 0.737466", \
          "0.047426, 0.108169, 0.147821, 0.241838, 0.368774, 0.537744, 0.699696", \
          "-0.004643, 0.056835, 0.096590, 0.190669, 0.317555, 0.486505, 0.648467");
      fall_transition(delay_template_7x7) {
        values ( \
          "0.029893, 0.101269, 0.153828, 0.297440, 0.505461, 0.786136, 1.055562", \
          "0.029839, 0.101283, 0.153775, 0.297432, 0.505460, 0.786137, 1.055562", \
          "0.030377, 0.101370, 0.153751, 0.297471, 0.505466, 0.786138, 1.055562", \
          "0.031000, 0.102126, 0.154293, 0.297598, 0.505512, 0.786157, 1.055567", \
          "0.033318, 0.103058, 0.154916, 0.297969, 0.505674, 0.786190, 1.055575", \
          "0.035085, 0.103979, 0.155717, 0.298306, 0.505886, 0.786349, 1.055660", \
          "0.037125, 0.105417, 0.156607, 0.298669, 0.506013, 0.786489, 1.055807");
    max_capacitance : 0.311500;
  cell_leakage_power : 1643.618394;
发表于 2012-11-4 11:51:48 | 显示全部楼层
回复 10# love80238023
   看看上面那个DFF库,咱们研究下,呵呵
发表于 2012-11-4 11:59:02 | 显示全部楼层
各个模板:
/* templates */
  lu_table_template(delay_template_7x1) {
    variable_1 : input_net_transition;
    index_1 ("1000, 1001, 1002, 1003, 1004, 1005, 1006");
  power_lut_template(energy_template_7x1) {
    variable_1 : input_transition_time;
  lu_table_template(delay_template_7x7) {
    variable_2 : total_output_net_capacitance;
    index_2 ("1000, 1001, 1002, 1003, 1004, 1005, 1006");
  power_lut_template(energy_template_7x7) {
  power_lut_template(energy_template_1x7) {
    variable_1 : total_output_net_capacitance;
  power_lut_template(energy_template_7x3x3) {
    variable_3 : equal_or_opposite_output_net_capacitance;
    index_2 ("1000, 1001, 1002");
    index_3 ("1000, 1001, 1002");
  power_lut_template(passive_energy_template_1x7) {
  lu_table_template(setup_template_3x3) {
    variable_1 : constrained_pin_transition;
    variable_2 : related_pin_transition;
    index_1 ("1000, 1001, 1002");
  lu_table_template(hold_template_3x3) {
  lu_table_template(recovery_template_3x3) {
  lu_table_template(removal_template_3x3) {
发表于 2012-11-4 12:05:27 | 显示全部楼层
回复 1# Gary.wang
   我发的库是确定了输入的。
我想问问库里面怎么hold有负值???
我学识较浅,求解~~~
发表于 2012-11-4 13:55:36 | 显示全部楼层
回复 14# wlbce
    It is interesting to note that in discussion of such a model, if the input
transition delay is large compared to the total cell delay, then the propagation
delay becomes negative. This negative time evaluation might
occur when the output changes before the input reaches the logic switching
threshold voltage. Although this negative value is alarming, it is not a
problem as long as the cell delay is a positive value. Therefore a careful
model validation is required when using this type of models.
--摘自 physical design essential
Physical_Design_Essentials.pdf (2.63 MB , 下载次数: 570 )
我的理解是:因为delay是50%至50%的时间,当input tran比较大时,确实有可能在输入不到50%时,输出已经到50%,这时候是Propagation delay是负的。
另外对于某些特殊单元,hold确实可以一直是负的(因为cell内部,clock pin的路径较短;D pin的路径较长)。
发表于 2012-11-4 20:33:06 | 显示全部楼层
回复 9# wlbce
我的理解是这个表是个二维表,表的x方向和y方向代表了clock的transition时间和D的transition时间。
发表于 2012-11-4 23:02:08 | 显示全部楼层
回复 16# lc113xd
   呵呵,我也是这么理解的,但莫名其妙楼主的库 没有 写这个模板。
发表于 2012-11-4 23:04:57 | 显示全部楼层
回复 15# sjtusonic
  哈哈~ 非常感谢!!理解了!真是好资料~~我好好研究研究~~
发表于 2015-3-21 16:21:09 | 显示全部楼层
我也下载来看看
发表于 2015-12-21 16:40:34 | 显示全部楼层
回复 8# chaobeyond
   大神,请教一下,为什么setup 和 hold值 取决于: clk 信号的transition 和 D 信号的transition,谢谢
GMT+8, 2025-12-19 01:59 , Processed in 0.020735 second(s), 6 queries , Gzip On, Redis On.
