查看: 2233|回复: 3
[求助] 菜鸟求教spectre仿真问题?!
发表于 2012-10-21 20:46:02 | 显示全部楼层 |阅读模式
要把下面的内容转化为cadence环境下spectre仿真的格式,转了半天,总是仿不通,论坛求高手! 谢了...
  1. *
  2. *       _/_/_/_/_/_/
  3. *     _/       _/
  4. *      _/_/   _/          STMicroelectronics
  5. *         _/ _/
  6. *   _/_/_/  _/
  7. *   www.st.com
  8. *
  9. *
  10. *****************************************************
  11. *     Model Generated by STMicroelectronics         *
  12. *             All Rights Reserved                   *
  13. *      Commercial Use or Resale Restricted          *
  14. *****************************************************
  15. * CREATION DATES: 17-11-2006                        *
  16. *                                                   *
  17. * POWER MOSFET Model (level 3)                      *
  18. *                                                   *
  19. * EXTERNAL PINS DESCRIPTION:                        *
  20. *                                                   *
  21. * PIN 1 -> Drain                                    *
  22. * PIN 2 -> Gate                                     *
  23. * PIN 3 -> Source                                   *
  24. *                                                   *
  25. *                    ****C****                      *
  26. *            **********************                 *
  27. *     ***************************************       *
  28. *  PARAMETER MODELS EXTRACTED FROM MEASURED DATA    *
  29. *              <<<<<<<<<<<>>>>>>>>>>>               *
  30. *     ***************************************       *
  31. *   THIS MODEL CAN BE USED AT TEMPERATURE: 25 癈    *
  32. *                                                   *
  33. *****************************************************
  34. * MODELLING FOR STQ2HNK60ZR-AP
  35. .SUBCKT STQ2HNK60ZR-AP 1 2 3
  36. LG 2 4  7.5E-09
  37. LS 12 3 7.5E-09
  38. LD 6 1  4.5E-09
  39. RG 4 5  6.001
  40. RS 9 12 0.151
  41. RD 7 6  3.487
  42. RJ 8 7  0.354E-01
  43. CGS 5 9   0.324E-09
  44. CGD 7 10  0.357E-09
  45. CK  11 7  0.427E-11
  46. DGD 11 7 DGD
  47. DBS 12 6 DBS
  48. DBD  9 7 DBD
  49. MOS  13 5 9 9 MOS L=1u W=1u
  50. E1  10 5 101 0 1
  51. E2  11 5 102 0 1
  52. E3  8 13 POLY(2) 6 8 6 12 0 0 0 0  0.255E-01
  53. G1  0 100 7 5 1u
  54. D1  100 101  DID
  55. D2  102 100  DID
  56. R1  101 0  1MEG
  57. R2  102 0  1MEG
  58. .MODEL MOS NMOS
  59. + LEVEL = 3
  60. + VTO   = 4.807
  61. + PHI   = 0.836
  62. + IS    = 0.1E-12
  63. + JS    = 0
  64. + THETA = 0.776E-01
  65. + KP    = 2.922
  66. .MODEL DGD D
  67. + IS    = 0.1E-12
  68. + CJO   = 0.375E-10
  69. + VJ    = 0.776
  70. + M     = 0.349
  71. .MODEL DBD D
  72. + IS    = 0.1E-12
  73. + CJO   = 0.169E-10
  74. + VJ    = 0.793
  75. + M     = 0.336
  76. .MODEL DBS D
  77. + IS    = 0.1E-12
  78. + BV    = 625
  79. + N     = 1
  80. + TT    = 0.199E-06
  81. + RS    = 0.479E-02
  82. .MODEL DID D
  83. + IS    = 0.01E-12
  84. + RS    = 0
  85. + BV    = 635
  86. .ENDS STQ2HNK60ZR-AP
  87. * END OF MODELLING
    复制代码
等待高手,菜鸟心声...再次感谢!
发表于 2012-10-24 22:51:05 | 显示全部楼层
level 3 啊
 楼主| 发表于 2012-10-25 10:32:25 | 显示全部楼层
回复 2# badmintonor
   是啊,改了好多次格式,总没仿通,贴出来求高手.
发表于 2012-10-25 11:34:17 | 显示全部楼层
用hspice跑啊
GMT+8, 2025-12-29 03:00 , Processed in 0.025256 second(s), 8 queries , Gzip On, Redis On.
