查看: 8169|回复: 3
[讨论] 大家能帮我看下这条路经吗?
发表于 2012-10-17 10:46:56 | 显示全部楼层 |阅读模式
Startpoint: SCANIN1_PAD
(input port clocked by ClkAtpg)
Endpoint: SCANOUT1_PAD
(output port clocked by ClkAtpg)
Path Group: ClkAtpg
Path Type: max
Min Clock Paths Derating Factor : 0.950000
Max Clock Paths Derating Factor : 1.000000
Point
Incr
Path
clock ClkAtpg (rise edge)
0.000000
0.000000
clock network delay (ideal)
0.000000
0.000000
input external delay
10.000000
10.000000 f
SCANIN1_PAD (inout)
0.000305 & 10.000305 f
uVD157_pad/uSCANIN1/PAD (PDU04SCDG)
8.991417 & 18.991722 f
uVD157_pad/uSCANIN1/C (PDU04SCDG)
11.348091 & 30.339813 f
uVD157_digital/uInf/U593/Z (AN2HVTD0)
0.241364 & 30.581177 f
uVD157_digital/FE_OFC3998_InfPGM/ZN (INVHVTD1P5)
0.292107 & 30.873283 r
uVD157_digital/FE_OFC3999_InfPGM/ZN (INVHVTD4)
0.374252 & 31.247536 f
uVD157_digital/uEfuse/U13/ZN (INVHVTD0)
0.298553 & 31.546089 r
uVD157_digital/uEfuse/U93/ZN (AOI22HVTD0)
0.187462 & 31.733551 f
uVD157_digital/uEfuse/U7/ZN (XNR3HVTD0)
0.469589 & 32.203140 f
uVD157_digital/uEfuse/U4/ZN (IAO22HVTD0)
0.255211 & 32.458351 f
uVD157_digital/uEfuse/U8/Z (AO22HVTD0)
0.373337 & 32.831688 f
uVD157_digital/FE_OFC287_EfuseInfDout/ZN (INVHVTD1P5)
0.313499 & 33.145187 r
uVD157_digital/FE_OFC288_EfuseInfDout/ZN (CKNXHVTD4)
0.452446 & 33.597633 f
uVD157_digital/uInf/U664/ZN (AOI22HVTD0)
0.657310 & 34.254944 r
uVD157_digital/uInf/U663/ZN (OAI21D4)
0.235207 & 34.490150 f
uVD157_pad/U7/Z (MUX2D4)
0.194923 & 34.685074 f
uVD157_pad/FE_OFC256_n11/Z (CKBXD16)
0.149406 & 34.834480 f
uVD157_pad/uSCANOUT1/PAD (PDU04SCDG)
9.886711 & 44.721191 f
SCANOUT1_PAD (inout)
90.782471 & 135.503662 f
data arrival time
135.503662
50.000000
50.000000
0.000000
50.000000
clock reconvergence pessimism
0.000000
50.000000
output external delay
-10.000000 40.000000
data required time
40.000000
data required time
40.000000
data arrival time
-135.503662
slack (VIOLATED)
-95.503662
该路径为一条直接从扫描输入到扫描输出端口的时序报告,但是有个奇怪的现象,这里从芯片的顶层输入端SCANIN1_PAD (inout)到uVD157_pad/uSCANIN1/PAD (PDU04SCDG) 这个IO的PAD端口的延时居然有 8.991417 ns,按理说这里就是一个net相连的啊,怎么会有这么大的延时呢?不知道有谁也遇到过这个问题?它可能与哪些因素有关?同样的,从uVD157_pad/uSCANOUT1/PAD (PDU04SCDG)的PAD端到芯片的顶层端口SCANOUT1_PAD (inout)的延时居然达到90.782471 ns。太让人崩溃了。
发表于 2012-10-17 12:49:21 | 显示全部楼层
PAD delay大是常事,至于那90ns到PAD,去检查它的input transition和output loading
 楼主| 发表于 2012-10-18 00:16:46 | 显示全部楼层
回陈老大AD大确实是经常遇到的现象,但是这里的delay却是出现在我的顶层Port端口到IO的PAD端口。而对于从IO的PAD到IO的C端口为9点几纳秒。这个还算是正常,但是那个port到IO的PAD端口那么大的延时就有点不是很清楚了。我也查看了下,我的port的transition为我自己设置的为0.6,而到达IO的PAD却变成了28.5ns。这个地方完全就是一根net的呀。不知道为什么变成这么大了。
发表于 2012-10-18 08:19:50 | 显示全部楼层
high fanout 或者 long wire都会造成28.5ns 的transition
GMT+8, 2025-12-28 09:58 , Processed in 0.015828 second(s), 4 queries , Gzip On, Redis On.
