查看: 22471|回复: 53
[求助] 关于map报错
发表于 2012-9-29 13:24:38 | 显示全部楼层 |阅读模式
Error: Layer "M1" (metal1) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "M2" (metal2) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "M3" (metal3) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "M4" (metal4) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "M5" (metal5) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
Error: Layer "M6" (metal6) exists in the MW-tech but not in the mapping AND ITF file. (TLUP-001)
fab提供的map如下:
conducting_layers
  POLY1          poly    RPSQ=7.85
  METAL1        metal1  RPSQ=0.11
  METAL2        metal2  RPSQ=0.065
  METAL3        metal3  RPSQ=0.065
  METAL4        metal4  RPSQ=0.065
  METAL5        metal5  RPSQ=0.065
  METAL6        metal6  RPSQ=0.0202
via_layers
   CONT      polyCont            AREA=0.0256 RPV=11
  VIA12          via1                 AREA=0.0361 RPV=1.0
  VIA23          via2                 AREA=0.0361 RPV=1.0
  VIA34          via3                 AREA=0.0361 RPV=1.0
  VIA45          via4                 AREA=0.0361 RPV=1.0
  VIA56         via5a                AREA=0.1296 RPV=0.45
想请问RPSQ和RPV的含义是什么?应该可以删除的吧?
itf:
VIA polyCont { FROM=poly TO=metal1 AREA=0.0256 RPV=1 }
VIA via1 { FROM=metal1 TO=metal2 AREA=0.0361 RPV=0.1 }
VIA via2 { FROM=metal2 TO=metal3 AREA=0.0361 RPV=0.1 }
VIA via3 { FROM=metal3 TO=metal4 AREA=0.0361 RPV=0.1 }
VIA via4 { FROM=metal4 TO=metal5 AREA=0.0361 RPV=0.1 }
VIA via5a { FROM=metal5 TO=metal6 AREA=0.1296 RPV=0.1 }
VIA via5b { FROM=mim    TO=metal6 AREA=0.1296 RPV=0.1 }
VIA viapa { FROM=metal6 TO=alpa   AREA=16.00  RPV=0.033}
对比了tf以后。修改了map。如下:左是tf右是itf。
conducting_layers
  GT            poly
  M1            metal1
  M2            metal2
  M3            metal3
  M4            metal4
  M5            metal5
  M6            metal6
via_layers
   CT         polyCont
   V1         via1
   V2         via2
   V3         via3
   V4         via4
   V5         via5a,via5b
由于PLL里面有mim,我想是不是map要加上via5b的信息?
不管是写V5         via5a,via5b 还是分两行写:
V5         via5a
V5         via5b
都还是报错如上。
请教。
谢谢!
发表于 2012-9-29 21:57:19 | 显示全部楼层
RPSQ和RPV
resistor per square
resistor per via
 楼主| 发表于 2012-9-30 08:32:17 | 显示全部楼层
回复 2# toad
    如此 多谢!那请大侠看看俺的map是有什么问题么~
发表于 2012-10-7 19:31:24 | 显示全部楼层
回复 1# half_honey
        今天遇到同样的问题starxtract报错,删掉几个VIA行和METAL行竟可以了,不过有一些warning。
     同样期待高手回答!!
 楼主| 发表于 2012-10-7 20:17:26 | 显示全部楼层
回复 4# fjmwu
    几个?能说的详细一点删了哪些吗?还有删了以后是什么warning呢?
 楼主| 发表于 2012-10-8 13:08:04 | 显示全部楼层
UP UP。。这个问题不解决place无能。。。求教。。。
发表于 2012-10-8 13:23:08 | 显示全部楼层
这个是转TLU+的map么?
 楼主| 发表于 2012-10-8 13:30:11 | 显示全部楼层
回复 7# damonzhao
    对的 全程就这一个map。。。
 楼主| 发表于 2012-10-8 13:31:11 | 显示全部楼层
回复 7# damonzhao
    问题是itf转tlu我没用map...grdgenxo -itf2TLUPlus -i  XXX.itf -o  XXXgrdgen.tluplus  &
发表于 2012-10-8 13:35:16 | 显示全部楼层
回复 9# half_honey
   为啥不用?貌似官方的用就行,不用改。
GMT+8, 2025-9-15 03:10 , Processed in 0.023920 second(s), 6 queries , Gzip On, Redis On.
