查看: 3688|回复: 2
[求助] 搭建10位理想ADC的问题
发表于 2012-9-27 21:36:45 | 显示全部楼层 |阅读模式
小弟搭建了一个10bit-DAC,为了仿真,调用“ahdlLib”库的“adc_8bit_ideal”,输出端为vd0-vd7,将里面的Veriloga代码做修改后得到10bit的理想ADC,并修改symbol,输出端为vd0-vd9,仿真时系统提示vd8vd9:“cannot be found in the switched master of the instance”,请各位指点,不胜感激。
发表于 2012-10-5 06:11:05 | 显示全部楼层
try delete the symbol, then change the verilog A, say, add one space anywhere, then close and save, see if it prompts you to generate a symbol view. If not, you need to edit the cdf parameter from CIW window.
 楼主| 发表于 2012-10-6 09:37:58 | 显示全部楼层
Using the methord you provide,I  have solved the problem. Thank you very much.
GMT+8, 2025-12-20 09:01 , Processed in 2.020772 second(s), 5 queries , Gzip On, Redis On.
