查看: 2673|回复: 0
FPGA访问SRAM,求助!!急!!
发表于 2006-4-15 23:16:08 | 显示全部楼层 |阅读模式
小弟用FPGA访问外部sram,用状态机实现,先向地址0x1里写了一个数2,再向地址0x2里写了一个数4,然后读地址0x1的数,始终不对!
程序如下,请各位指教:如有更好的方法请赐教!
library ieee;
use ieee.std_logic_1164.all;
entity sram is
port (
       clk,rst : in std_logic;
       saddr : out std_logic_vector(16 downto 0);
       dataio: out std_logic_vector(15 downto 0);
       sram_wrenut std_logic;--sram写使能,低有效
       sram_rdenut std_logic;--sram输出使能,低有效
       sdata : inout std_logic_vector(15 downto 0)
end sram ;
architecture behavor of i486_bus is
signal state,next_state :std_logic_vector(1 downto 0);
begin
process(clk)
begin
   if rst='1'then
       state<="00";
   elsif clk'event and clk='1'then
       state<=next_state;
   end if;
end process;
process(state)
begin
case state is
       when "00"=>
               sram_wren<='0';--写数据
               sram_rden<='1';
               saddr<="00000000000000001";--地址0x1
               sdata<="0000000000000100";--写入数据 4
               next_state<="01";
       when "01"=>
               sram_rden<='1';
               saddr<="00000000000000010";--地址0x2
               sdata<="0000000000000010";----数据2
               next_state<="10";
       when "10"=>
               sram_wren<='1';--读数据
               sram_rden<='0';
               dataio<=sdata;--数据输出到io口上,测量该io口数据不对
               next_state<="10";--循环读该地址
       end case;
end process;
GMT+8, 2025-11-16 03:07 , Processed in 0.017024 second(s), 5 queries , Gzip On, Redis On.
