查看: 2189|回复: 1
[讨论] FPGA
发表于 2012-9-25 16:52:20 | 显示全部楼层 |阅读模式
Clock Net    |   Resource      |Locked|Fanout|Net Skew(ns)|Max Delay(ns)|
| clk2_OBUF* |  BUFGMUX_X1Y0     | No   |  110 |  0.000     |             |
| clk1_n_OBUF* | BUFGMUX_X2Y10| No   |  241 |  0.000     |             |
|u1/U7/clk_s1* |  BUFGMUX_X2Y1  | No   |    3 |  0.000     |             |
|  clk90_OBUF* |         Local            |      |    4 |  0.000     |             |
是不是说明时钟不能使用呢
ERRORlace:962 - A DCM / BUFGCTRL clock component pair have been found that are not placed at an optimal DCM / BUFGCTRL
   site pair. The DCM component <u1/U7/p2/DCM_SP_INST> is locked to site <DCM_X2Y0> and the corresponding BUFGCTRL
   component <u1/U7/p2/CLK180_BUFG_INST> is locked to site <BUFGMUX_X2Y10>.
这个X和Y是什么意思呢
 楼主| 发表于 2012-9-25 17:10:07 | 显示全部楼层
PIN "u1/U7/p1/DCM_SP_INST.CLKFX" CLOCK_DEDICATED_ROUTE = FALSE;
  PIN "u1/U7/p2/DCM_SP_INST.CLK180" CLOCK_DEDICATED_ROUTE = FALSE;
这是不是说明CLKFX和CLK180没有用到呢
GMT+8, 2025-12-23 13:10 , Processed in 0.011743 second(s), 3 queries , Gzip On, Redis On.
