查看: 4273|回复: 1
[求助] 仿真
发表于 2012-9-24 15:38:33 | 显示全部楼层 |阅读模式
`timescale 1 ns/ 1ns
module temp(clk,cout);
input clk;
output [7:0] cout;
reg out;
reg [3:0] a;
reg [2:0] count;
reg [7:0] ct;
always@(posedge clk)
if(a==4'hf)begin
a<=4'h0;
out<=~out;
end
else
    a<=a+1'b1;
always@(posedge out)
if(count==3'h7)begin
count<=3'h0;
end
else
    count<=count+1'b1;
always@(*)
case(count)
        3'h0:ct<=8'h55;
        3'h1:ct<=8'haa;
        3'h2:ct<=8'hdc;
        3'h3:ct<=8'h24;
        3'h4:ct<=8'hf0;
        3'h5:ct<=8'h0f;
        3'h6:ct<=8'h6c;
        3'h7:ct<=8'hc4;
        default:ct<=8'h0;
        endcase
assign cout=ct;
          endmodule
module tb;
  reg clk=1'b0;
  wire [7:0] cout;
  always clk =#5 ~clk;
   temp temp(.clk(clk),.cout(cout));
endmodule
为什么只有时钟信号,其他信号看不到啊
发表于 2012-9-24 17:10:22 | 显示全部楼层
这个问题很奇怪啊
temp只有输入信号 clk,输出信号cout,tb负责产生clk信号,你还有什么信号看不到的?
GMT+8, 2025-12-21 21:37 , Processed in 0.011407 second(s), 3 queries , Gzip On, Redis On.
