查看: 4706|回复: 6
[求助] 新手请教:为什么用.18工艺综合出来的面积比.35还大??
发表于 2012-9-8 18:34:20 | 显示全部楼层 |阅读模式
首先DC综合报告的面积单位是什么?
另外DC报告中的连线面积说明了什么??为什么一个工艺库出来的连线面积比例很小,另一个却很大??
同样的设计,用Chartered 0.18工艺库综合出来的面积比0.35工艺库的面积还大,下面是DC的面积报告
首先是.35的:
Library(s) Used:
    CSM35OS142_typ (File: /home/tian/work/design_compiler/library/synopsys_35/models/CSM35OS142_typ.db)
Number of ports:                8
Number of nets:               318
Number of cells:              217
Number of references:          26
Combinational area:        706.900003
Noncombinational area:     450.660000
Net Interconnect area:     490.344310
Total cell area:          1157.560003
Total area:               1647.904313
Hierarchical area distribution
                                  Global cell area          Local cell area
Hierarchical cell                 Absolute   Percent  Combi-    Noncombi-  Black
                                  Total      Total    national  national   boxes   Design
single_loop                       1157.5605    100.0  173.2502   450.6600  0.0000  single_loop
add_0_root_add_0_root_add_37_2      75.1300      6.5   75.1300     0.0000  0.0000  single_loop_DW01_add_3
add_1_root_add_0_root_add_37_2     115.3300     10.0  115.3300     0.0000  0.0000  single_loop_DW01_add_4
add_1_root_sub_0_root_add_33       104.5301      9.0  104.5301     0.0000  0.0000  single_loop_DW01_add_5
add_34                             119.3300     10.3  119.3300     0.0000  0.0000  single_loop_DW01_add_1
add_35                             119.3300     10.3  119.3300     0.0000  0.0000  single_loop_DW01_add_0
Total                                                 706.9003   450.6600  0.0000
然后是.18的
Library(s) Used:
    scx_csm_18ic_tt_1p8v_25c (File: /home/tian/work/design_compiler/library/synopsys_18/scx_csm_18ic_tt_1p8v_25c.db)
Number of ports:                8
Number of nets:               246
Number of cells:              138
Number of references:          29
Combinational area:       7361.323257
Noncombinational area:    5059.454521
Net Interconnect area:    73640.381165
Total cell area:          12420.777779
Total area:               86061.158943
single_loop                       12420.7852    100.0   791.6831  5059.4551  0.0000  single_loop
add_0_root_add_0_root_add_37_2      804.9888      6.5   804.9888     0.0000  0.0000  single_loop_DW01_add_3
add_1_root_add_0_root_add_37_2     1580.0396     12.7  1580.0396     0.0000  0.0000  single_loop_DW01_add_4
add_1_root_sub_0_root_add_33        911.4338      7.3   911.4338     0.0000  0.0000  single_loop_DW01_add_5
add_34                             1636.5884     13.2  1636.5884     0.0000  0.0000  single_loop_DW01_add_1
add_35                             1636.5884     13.2  1636.5884     0.0000  0.0000  single_loop_DW01_add_0
Total                                                  7361.3218  5059.4551  0.0000
发表于 2012-9-8 19:55:06 | 显示全部楼层
DC综合面积单位um^2
请设置zeroloadModel重新综合查看结果,并对比
035----018综合结果cell数量少了,但是面积翻了10倍,进入lib库查看对比单元,report_area设置详细选项查看单元面积都行,应该非常好debug
发表于 2012-9-10 09:36:24 | 显示全部楼层
两个工艺库lib文件的面积单位是否一致呢?
 楼主| 发表于 2012-9-10 10:14:09 | 显示全部楼层
回复 3# magic14
问题就在这里,从哪里可以看到库的长度单位呢
发表于 2012-9-10 10:36:17 | 显示全部楼层
蒙一下,或找后端问问,或者打开layout看一下。
发表于 2012-9-10 11:42:33 | 显示全部楼层
回复 4# 禅师1988
    cell LEF
发表于 2012-9-12 00:13:12 | 显示全部楼层
那个test case太小,基本上说明不了什么问题
GMT+8, 2025-12-21 11:35 , Processed in 0.020266 second(s), 6 queries , Gzip On, Redis On.
