查看: 6390|回复: 7
Cadence Allegro SPB 16.5 Hotfix S028
发表于 2012-9-2 13:42:48 | 显示全部楼层 |阅读模式
Cadence最新版软件SPB 16.5及其Hotfix_SPB16.50.028_wint_1of1.exe下载链接如下:
http://dl.vmall.com/c037uexo72
Cadence Allegro SPB 16.5 的最新(截止到2012年9月1日)补丁S028,对以下项目做了修正:
DATE: 08-23-2012   HOTFIX VERSION: 028
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
320014  ALLEGRO_EDITOR EDIT_ETCH        Differential pair fail to Slide together
400672  ALLEGRO_EDITOR EDIT_ETCH        The Diffpair rule is disregarded because of the insertion of Via.
448641  ALLEGRO_EDITOR EDIT_ETCH        Diff pairs do not slide when the xnet is broken
501605  ALLEGRO_EDITOR EDIT_ETCH        Diff Pair Sliding problem
731162  ALLEGRO_EDITOR EDIT_ETCH        Slide and Delay Tune on Diff pair tunes only one net when Single trace mode is not ON.
967082  SIG_INTEGRITY  SIGNOISE         signoise command didn't use Frequency set on Net.
979958  SIP_LAYOUT     ASSY_RULE_CHECK  Running Assembly Rules Check on sip causes a crash
984604  ALLEGRO_EDITOR EDIT_ETCH        Error when trying to split via stack
988446  APD            OTHER            Beginning layer regular pad cannot change to Null.
995108  ALLEGRO_EDITOR GRAPHICS         Strange unexpected lines show across the oblong padstack
1021557 RF_PCB         DISCRETE_LIBX_2A Translator dxlib2iff lists cells alphanumerically inverted.
1021568 RF_PCB         DISCRETE_LIBX_2A translator GUI not listing library cells alphabetically in Linux/Unix
1024239 ALLEGRO_EDITOR INTERFACES       DXF pin location is moved when I execute DXF out
1039112 ALLEGRO_EDITOR ARTWORK          Antietch and Boundary layers deleted when Match Display selected
1039751 SCM            SCHGEN           SCHGEN is bunching voltage flags together to the point they're illegible
1040584 ALLEGRO_EDITOR GRAPHICS         After installing Hotfix 16.5s026  3D viewer has been impacted..
1040653 ALLEGRO_EDITOR DATABASE         Cannot update netlist data,  ERROR(SPMHDB-121): Attribute definition not found.
1041368 APD            DEGASSING        The Degas_No_Void properties assigned to Cline does not work.
1041864 ALLEGRO_EDITOR MANUFACT         Allegro crashes when opening the Backdrill setup menu
1042004 SIP_LAYOUT     DIE_STACK_EDITOR Moving die pad layer from top to bottom of package is not change the die stack side
1043777 ADW            COMPONENT_BROWSE ADW UCB must support hyperlinks in Database Mode like we do in Non-DB Mode
1043861 SIG_INTEGRITY  REPORTS          Derating values are NA in bus simulation report when derating table is not in working directory
发表于 2012-9-16 02:34:09 | 显示全部楼层
资源不错!感谢分享!
发表于 2012-10-19 11:41:57 | 显示全部楼层
谢谢分享!
发表于 2012-10-19 11:42:41 | 显示全部楼层
谢谢分享
发表于 2012-10-21 11:36:37 | 显示全部楼层
http://dl.vmall.com/c08b52ru1z 这个是最新的,S031补丁及完整安装盘
发表于 2012-11-18 23:51:39 | 显示全部楼层
谢谢楼主
发表于 2012-12-13 13:46:25 | 显示全部楼层
能和谐吗?
发表于 2013-4-11 16:54:35 | 显示全部楼层
先下来看看,有没有教程教破解的呢
GMT+8, 2025-12-19 13:17 , Processed in 0.025546 second(s), 6 queries , Gzip On, Redis On.
