楼主: magic14
[求助] tsmc40LP-9T,tsmc40G-9T,tsmc40G-12T, tsmc65G-12T这几个的速度差异是怎样的?
发表于 2012-8-28 10:33:24 | 显示全部楼层
9T和12T理论上速度差得不会很多,LP应该慢得明显。
9tracks 只是cell 驱动弱些,可以用X2,X4去抵消。
40G-9T应该没问题。
发表于 2016-10-31 21:28:28 | 显示全部楼层
好好好好好好好好好好好好
发表于 2017-5-5 22:38:38 | 显示全部楼层
需要了解什么是跟踪及其影响
发表于 2017-5-6 06:38:04 | 显示全部楼层
回复 1# magic14
40LP-9T is low power process while 40G-9T is for general purpose process, typically, the G one is faster40G-9T and 40G-12T should be the same timing wise
40G-12T is 40nm tech node, while  65G-12T is older tech node, 40G one should be faster.
发表于 2017-7-11 23:13:08 | 显示全部楼层
Thank you very much
发表于 2020-5-16 22:48:17 | 显示全部楼层
eeares 发表于 2012-8-22 11:17
回复 2# jiancongwoo
Thank you
发表于 2020-7-24 02:53:53 | 显示全部楼层
nice to read good one
发表于 2020-12-11 10:30:15 | 显示全部楼层
xiaoyisimonguo 发表于 2017-5-6 06:38
回复 1# magic14
40LP-9T is low power process while 40G-9T is for general purpose process, typicall ...
very good
GMT+8, 2025-12-28 07:40 , Processed in 0.017203 second(s), 4 queries , Gzip On, Redis On.
