查看: 4535|回复: 1
[求助] HSPICE问题求助
发表于 2012-8-16 10:23:50 | 显示全部楼层 |阅读模式
我安装的是坛子下载的hspice 2011在它自带的demo里面找了一个bjt的仿真的sp文件,我运行了下:
bash$:hspice bjtbeta.sp
结果提示是:
Using: /home/mytools/synopsys/hspice201109/hspice/linux/hspice bjtbeta.sp
****** HSPICE -- F-2011.09-SP1 32-BIT (Nov 18 2011) linux ******
  Copyright (C) 2011 Synopsys, Inc. All Rights Reserved.
  Unpublished-rights reserved under US copyright laws.
  This program is protected by law and is subject to the
  terms and conditions of the license agreement from Synopsys.
  Use of this program is your acceptance to be bound by the
  license agreement. HSPICE is the trademark of Synopsys, Inc.
  Input File: bjtbeta.sp
  Command line options: bjtbeta.sp
lic:
lic: FLEXlm: v10.8
lic: USER:   XXX                  HOSTNAME: XXX
lic: HOSTID: XXXXXXXXXXX         PID:      31465
lic: Using FLEXlm license file:
lic: 27000@XXX
lic: Checkout 1 hspice
lic: License/Maintenance for hspice will expire on 31-dec-2019/2019.12
lic: 1(in_use)/9999(total) FLOATING license(s) on SERVER ycp-pc
lic:
Init: read install configuration file: /home/mytools/synopsys/hspice201109/hspice/meta.cfg
1****** HSPICE -- F-2011.09-SP1 32-BIT (Nov 18 2011) linux ******
*file:bjtbeta.sp
  ******  bjt   model parameters tnom=  25.000 temp=  25.000 *****
*** bjt model parameters   model name:   0:n1       model type:npn   ***
     names  values   units     names  values   units     names  values   units
   1*** basic dc parameters ***
    level=   1.00                bf= 100.00                br=   1.00
      brs=   0.                bulk=  gnd                  is=  10.00f amps
      iss=   0.    amps          nf=   1.00                nr=   1.00
       ns=   1.00               ibe=   0.    amps         ibc=   0.    amps
     subs=   1.00             expli=   0.    amps
   2*** low current beta degradation effect parameters ***
      isc=   0.    amps         ise=   2.00p amps          nc=   2.00
       ne=   2.00
   3*** base width modulation parameters ***
      vaf=   0.    volts        var=   0.    volts
   4*** high current beta degradation effect parameters ***
      ikf=  20.00m amps         nkf= 500.00m              ikr=   0.    amps
   5*** parasitic resistor parameters ***
      irb=   0.    amps          rb=   0.    ohms         rbm=   0.    ohms
       re=   0.    ohms          rc=   0.    ohms         rcc=   0.    ohms
       vo=   0.    volts      gamma=   0.
   6*** junction capacitor parameters ***
     cbcp=   0.    farad       cbep=   0.    farad       ccsp=   0.    farad
      cjc=   0.    farad        cje=   0.    farad        cjs=   0.    farad
       fc= 500.00m              mjc= 330.00m              mje= 330.00m
      mjs= 500.00m              vjc= 750.00m volts        vje= 750.00m volts
      vjs= 750.00m volts       xcjc=   1.00               qco=   0.    coul
   7*** transit time parameters ***
      itf=   0.    amps         ptf=   0.    deg k         tf=   0.    secs
       tr=   0.    secs         vtf=   0.                 xtf=   0.
   8*** temperature compensation parameters ***
     tlev=   0.               tlevc=   0.                tre1=   0.    /deg
     tre2=   0.    /deg2       trb1=   0.    /deg        trc1=   0.    /deg
     trb2=   0.    /deg2       trm1=   0.    /deg         xtb=   0.
     trm2=   0.    /deg2        xti=   3.00               cte=   0.    /deg
      ctc=   0.    /deg         cts=   0.    /deg        trc2=   0.    /deg2
     tref=  25.00   deg c       bex=   2.42              bexv=   1.90
   9*** noise parameters ***
       kf=   0.                  af=   1.00
******  option summary
runlvl  = 3         bypass  = 2
          ***** job concluded
*file:bjtbeta.sp
  ******  job statistics summary tnom=  25.000 temp=  25.000 *****
******  Machine Information  ******
CPU:
model name
: Intel(R) Core(TM) i5 CPU         650  @ 3.20GHz
cpu MHz
: 1200.000
OS:
Linux version 2.6.32-41-generic-pae (buildd@aatxe) (gcc version 4.4.3 (Ubuntu 4
.4.3-4ubuntu5.1) ) #91-Ubuntu SMP Wed Jun 13 12:00:09 UTC 2012
  ******  HSPICE Threads Information  ******
  Command Line Threads Count :     1
  Available CPU Count        :     4
  Actual Threads Count       :     1
  ******  Circuit Statistics  ******
  # nodes       =       6 # elements   =       6
  # resistors   =       1 # capacitors =       0 # inductors   =       0
  # mutual_inds =       0 # vccs       =       0 # vcvs        =       0
  # cccs        =       0 # ccvs       =       0 # volt_srcs   =       3
  # curr_srcs   =       1 # diodes     =       0 # bjts        =       1
  # jfets       =       0 # mosfets    =       0 # U elements  =       0
  # T elements  =       0 # W elements =       0 # B elements  =       0
  # S elements  =       0 # P elements =       0 # va device   =       0
  # vector_srcs =       0
  ******  Runtime Statistics (seconds)  ******
  analysis           time    # points   tot. iter  conv.iter
  op point           0.00           1           0
  dc sweep           0.00          51         164
  readin             0.01
  errchk             0.01
  setup              0.00
  output             0.00
           peak memory used         95.55 megabytes
           total cpu time            0.02 seconds
           total elapsed time        1.28 seconds
           job started at     10:16:31 08/16/2012
           job ended   at     10:16:32 08/16/2012
>info:         ***** hspice job concluded
lic: Release hspice token(s)
最后这个是个什么问题呢。。。
 楼主| 发表于 2012-8-16 10:46:05 | 显示全部楼层
貌似是我拷贝的东西的问题。。。
GMT+8, 2025-12-28 09:57 , Processed in 0.015210 second(s), 6 queries , Gzip On, Redis On.
