查看: 2883|回复: 0
[求助] xps编译出错,求解答
发表于 2012-8-13 17:10:41 | 显示全部楼层 |阅读模式
ISE版本是13.2,在xps环境下用chipscope创建IP核对工程进行调试。工程对应的是xilinx atlys板子,以下三个出错的接口都属于MCB_DDR2模块,接入的IP核是VIO核与ila核。这种错误该怎么解决呢?
ERROR:NgdBuild:809 - output pad net 'fpga_0_MCB_DDR2_mcbx_dram_ras_n_pin' has an
   illegal load:
ERROR:NgdBuild:809 - output pad net 'fpga_0_MCB_DDR2_mcbx_dram_cas_n_pin' has an
   illegal load:
ERROR:NgdBuild:809 - output pad net 'fpga_0_MCB_DDR2_mcbx_dram_we_n_pin' has an
   illegal load:
ERROR:Xflow - Program ngdbuild returned error code 2. Aborting flow execution...
GMT+8, 2025-12-20 11:36 , Processed in 0.018106 second(s), 5 queries , Gzip On, Redis On.
