查看: 2939|回复: 2
[求助] DCM 使用
发表于 2012-8-8 13:34:42 | 显示全部楼层 |阅读模式
一个开源的代码用Synplify Pro综合,然后将.edf文件在ISE中建立工程,由于使用到了DCM资源,出现了些问题,下面这是与ISE爆出问题有关的.edf文件部分内容,请各位帮忙分析解决下。
(instance (rename sd2_sdbuf "sd2.sdbuf") (viewRef PRIM (cellRef OBUF_F_12 (libraryRef VIRTEX)))
(net sdclk (joined
(portRef O (instanceRef sd2_sdbuf))
(portRef sdclk)
(net sdclki (joined
(portRef CLK0 (instanceRef sd0_dll1))
(portRef I (instanceRef sd2_sdbuf))
其中OBUF_F_12为代码中定义的,具体如下
component OBUF_F_12 port( O : out std_ulogic; I : in
std_ulogic ); end component;
Map不能通过,会有如下的错误:
ERRORhysDesignRules:1577 - Illegal routing. The DCM_ADV block
<clkgen0/c2.v/sd0.dll1/DCM_ADV> has CLK output pin <CLK0> with incomplete or
incorrect connectivity. Routing from the <CLK0> pin to a BUFG, BUFGCTRL or
PLL_ADV block type was not found. The DCM_ADV CLK output pins can only route
to BUFG, BUFGCTRL or PLL_ADV block types.
ERRORack:1642 - Errors in physical DRC.
如果将网表中sd2_sdbuf直接改为BUFG
(instance
sd2_sdbuf (viewRef PRIM (cellRef BUFG (libraryRef VIRTEX)))
(net sdclk (joined
(portRef sdclk)
(net sdclki (joined
MapPlace & Route可以通过,但是在 Genreate Programming File会有如下的错误:
PhysDesignRules: 950-Dangling pins on block:<clkgen0/c2.v/sd0.dll1/DCM_ADV>:<DCM_ADV_DCM_ADV>. Must have a signal on one of the output clock pins.
Bitgen:25 - DRC detected 1 errors and 1 warnings. Please see the previously displayed individual error or warning messages for more details
选用的器件是Xilinxxc5vlx110
发表于 2012-8-8 15:09:51 | 显示全部楼层
try it again
发表于 2012-8-8 16:25:21 | 显示全部楼层
如果将网表中sd2_sdbuf直接改为BUFG:
源代码你有,为啥不改源码,而要改网表文件?
上面的提示说得很清楚了,因为时钟出去是要用到时钟布线资源的,PLL出去的就直接上全球时钟网络好了。
GMT+8, 2025-12-23 04:52 , Processed in 0.020072 second(s), 8 queries , Gzip On, Redis On.
