楼主: uptorich
[求助] mmsim10.1的spectre报错,不识别AHDL?
发表于 2012-11-15 08:35:48 | 显示全部楼层
回复 10# meteorlay
   ERROR信息如下:
    dac_8bit_ideal_func.c:1:18: error: math.h: No such file or directory
dac_8bit_ideal_func.c:2:20: error: stdlib.h: No such file or directory
dac_8bit_ideal_func.c:3:20: error: string.h: No such file or directory
In file included from dac_8bit_ideal_inst_static.h:18,
                 from dac_8bit_ideal_func.c:4:
/home/vvvv/cadence/install/IC6151/MMSIM10/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:22:20: error: setjmp.h: No such file or directory
/home/vvvv/cadence/install/IC6151/MMSIM10/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:30:20: error: values.h: No such file or directory
/home/vvvv/cadence/install/IC6151/MMSIM10/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:49:19: error: stdio.h: No such file or directory
In file included from /home/vvvv/cadence/install/IC6151/MMSIM10/tools.lnx86/systemc/gcc/4.4/install/lib/gcc/i686-pc-linux-gnu/4.4.0/include-fixed/syslimits.h:7,
请问这是什么原因?
发表于 2012-11-15 23:29:06 | 显示全部楼层
都是什么.c的错误, 估计还是和系统安装有关. 不过有个事情可以试试, 在ADE里面, 选择setup->environment, 然后勾中64位, 然后跑下试试?
点评
刚试了 好像不行  发表于 2024-10-16 10:48
发表于 2012-11-19 16:59:31 | 显示全部楼层
回复 12# meteorlay
    谢谢啊
发表于 2013-6-20 15:35:00 | 显示全部楼层
怎么解决的,求教!
发表于 2013-9-11 13:01:42 | 显示全部楼层
回复 1# uptorich
   同问,求解!
发表于 2013-11-9 01:54:15 | 显示全部楼层
我也遇到了这个问题,请问有人知道解决方法吗?
发表于 2013-11-17 12:39:52 | 显示全部楼层
回复 16# math123
   解决了吗?
发表于 2013-11-17 16:50:54 | 显示全部楼层
回复 17# tuzhuke
还没,似乎除了用带AHDL的电阻model外一切正常,正打算换redhat as5试试呢
 楼主| 发表于 2013-11-19 15:50:52 | 显示全部楼层
应该还是系统的关系
发表于 2013-11-30 21:57:01 | 显示全部楼层
回复 1# uptorich
   Install CPP rpm and GCC it will work
GMT+8, 2025-12-30 23:10 , Processed in 0.021076 second(s), 4 queries , Gzip On, Redis On.
