查看: 2536|回复: 2
[求助] 关于写uart接收的问题
发表于 2012-8-6 23:26:55 | 显示全部楼层 |阅读模式
想要请问个uart接收的问题
  1. library ieee;
  2. use ieee.std_logic_1164.all;
  3. use ieee.std_logic_unsigned.all;
  4. entity uart is
  5. port(
  6. clk_in_325hz : in std_logic;--153600hz由50MHZ分頻
  7. rxd_in: in std_logic;
  8. rxd_out:out std_logic_vector(7 downto 0)
  9. );
  10. end uart;
  11. architecture a of uart is
  12. type state is(idle,check,rec);
  13. signal check_ck,rec_ck,rec_re,rec_cc,ok:std_logic;
  14. signal check_re: std_logic_vector(1 downto 0):="00";
  15. signal recv,recv_sig : std_logic_vector(8 downto 0):="000000000";
  16. signal rxd_ck,rxd_ck_sig : std_logic_vector(3 downto 0):="0000";
  17. signal sta : state;
  18. begin
  19. process(sta,rxd_in,check_re,rec_re)
  20. begin
  21. case sta is
  22. when idle=>--等待初始位元
  23. recv_sig<="000000000";
  24. if rxd_in='0' then
  25. sta<=check;
  26. else
  27. sta<=idle;
  28. end if;
  29. when check=>--確認初始位元是不是雜訊
  30. check_ck<='1';
  31. case check_re is
  32. when "01"=>
  33. check_ck<='0';
  34. sta<=rec;
  35. when "10"=>
  36. check_ck<='0';
  37. sta<=idle;
  38. when others=> null;
  39. end case;
  40. when rec=>--接收資料
  41. rec_ck<='1';
  42. if rec_re='1' then
  43. sta<=idle;
  44. rec_ck<='0';
  45. elsif ok='1' then
  46. rxd_out<=recv(7 downto 0);
  47. sta<=idle;
  48. rec_ck<='0';
  49. end if;
  50. end case;
  51. end process;
  52. process(clk_in_325hz,check_ck,rec_ck)
  53. variable rxd_ck_st : integer range 0 to 4:=0;
  54. variable rec_st : integer range 0 to 8:=0;
  55. variable rec_ck_st: integer range 0 to 9:=0;
  56. begin
  57. if check_ck='1' then--確認初始位元是不是雜訊
  58. if clk_in_325hz'event and clk_in_325hz='1' then--1153600的上延
  59. if rxd_ck_st/=4 then--讓他記數4次,採樣4次確認是不是起始位元
  60. rxd_ck_st:=rxd_ck_st+1;
  61. rxd_ck<=rxd_in & rxd_ck_sig(3 downto 1);
  62. else
  63. if rxd_ck="0000" then--4次之後判斷回傳結果
  64. check_re<="01";
  65. rxd_ck_st:=0;
  66. else
  67. check_re<="10";
  68. rxd_ck_st:=0;
  69. end if;
  70. end if;
  71. end if;
  72. end if;
  73. if rec_ck='1' then
  74. if clk_in_325hz'event and clk_in_325hz='1' then
  75. rec_st:=rec_st+1;
  76. if rec_st=8 then --讓他記數8次,第8次的時候剛好再中間,共取9次,8個資料1個停止
  77. recv<=rxd_in & recv_sig(8 downto 1);
  78. rec_st:=0;
  79. rec_ck_st:=rec_ck_st+1;
  80. elsif rec_ck_st=9 then--取完第9個判斷第9個是不是停止位元,之後回傳
  81. if recv(8)='1' then
  82. ok<='1';
  83. rec_ck_st:=0;
  84. else
  85. rec_re<='1';
  86. rec_ck_st:=0;
  87. end if;
  88. end if;
  89. end if;
  90. end if;
  91. end process;
  92. end a;
    复制代码
这样写烧进实验板没有反应,这我的写法有错吗(?),9600bps的,先谢谢
发表于 2012-8-7 11:30:53 | 显示全部楼层
不能用signal tap一点点调试吗?
先查下输入输出有没有。
另外,代码最好是先仿真再上板子调,这是一个好习惯。仿真查问题比上板要容易多了。
发表于 2012-8-7 12:57:43 | 显示全部楼层
你为什么不仿真呢?而是直接上板子呢
GMT+8, 2025-12-25 16:39 , Processed in 0.029541 second(s), 8 queries , Gzip On, Redis On.
