本人用的是spartan6板子的,用IP核产生个时钟输出。可是每次到综合就出现这样错误
ERROR lace:1206 - This design contains a global buffer instance,
<instance_name/clkout1_buf>, driving the net, <clk_out_OBUF>, that is driving
the following (first 30) non-clock source pins off chip.
< PIN: clk_out.O; >
This design practice, in Spartan-6, can lead to an unroutable situation due
to limitations in the global routing. If the design does route there may be
excessive delay or skew on this net. It is recommended to use a Clock
Forwarding technique to create a reliable and repeatable low skew solution:
instantiate an ODDR2 component; tie the .D0 pin to Logic1; tie the .D1 pin to
Logic0; tie the clock net to be forwarded to .C0; tie the inverted clock to
.C1. If you wish to override this recommendation, you may use the
CLOCK_DEDICATED_ROUTE constraint (given below) in the .ucf file to demote
this message to a WARNING and allow your design to continue. Although the net
may still not route, you will be able to analyze the failure in FPGA_Editor.
< PIN "instance_name/clkout1_buf.O" CLOCK_DEDICATED_ROUTE = FALSE; >
ERROR lace:1136 - This design contains a global buffer instance,
the following (first 30) non-clock source pins.
< PIN: clk_out.O; >
This is not a recommended design practice in Spartan-6 due to limitations in
the global routing that may cause excessive delay, skew or unroutable
situations. It is recommended to only use a BUFG resource to drive clock
loads. If you wish to override this recommendation, you may use the
Phase 2.7 Design Feasibility Check (Checksum:4fdeefbf) REAL time: 5 secs
Total REAL time to Placer completion: 5 secs
Total CPU time to Placer completion: 5 secs
ERROR ack:1654 - The timing-driven placement phase encountered an error.
Mapping completed.
See MAP report file "clk_map.mrp" for details.
Problem encountered during the packing phase.
Design Summary
Number of errors : 3
Number of warnings : 0
Process "Map" failed |
