查看: 11292|回复: 22
[求助] 请问这电路架构的学名是什么?
发表于 2012-7-5 16:00:06 | 显示全部楼层 |阅读模式
如下图所示,有人可以告诉我这电路架构的学名是什么吗?
发表于 2012-7-5 16:09:33 | 显示全部楼层
回复 1# shaq
   looks like LDO
发表于 2012-7-5 16:28:19 | 显示全部楼层
回复 1# shaq
    unit buffer
发表于 2012-7-5 16:33:06 | 显示全部楼层
回复 3# fuyibin
   下面那个电流镜有什么作用?
发表于 2012-7-5 17:23:57 | 显示全部楼层
the current mirror is just a bias of output stage or branch.
if A1 is a single stage opamp, this circuit is just like a 2 stage opamp but without compensation capacitor.
therefore it maybe have the stability issue.
 楼主| 发表于 2012-7-5 17:52:41 | 显示全部楼层
if A1 is a single stage opamp, thi ...
fuyibin 发表于 2012-7-5 17:23
Thanks!! This is what I want!!!
发表于 2012-7-5 18:18:09 | 显示全部楼层
回复 5# fuyibin
   Ok!Thanks a lot!
   But why did they design buffer like this? What's the advantages ?
发表于 2012-7-5 18:30:06 | 显示全部楼层
回复 6# shaq
   Where did you find this circuit ? Which application is it used for ?
发表于 2012-7-5 22:43:52 | 显示全部楼层
Replica Bias
发表于 2012-7-6 00:20:06 | 显示全部楼层
回复 1# shaq
    他们都说的不对。
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 23:07 , Processed in 0.130785 second(s), 6 queries , Gzip On, Redis On.
